Been getting a p0269 code, so I did a bubble test and... no bubbles! where do I go now? Wiring harness?
By the way I recently had the FICM rebuilt, cleaned turbo, And new egr cooler.
C13888B (X2 ) , the middle one
P0269 = when maximum / minimum. Pulse width adder is exceeded a fault is set. Cylinder weak due to mechanical problem or injectors are not contributing necessary volume of fuel. ( but you already knew that )
