Sponsored by: Real Truck
superchip
Old Oct 2, 2012 | 04:22 PM
blm250's Avatar
blm250
superchip
Hi Guys:
I started having trouble with my f250 running rough scanned gave code of CPS that didnt work then would start I disconnected ICP got it to start. I replaced ICP took on test drive about 3 miles ran well, next day started and was idling very rough especially when shift into drive. I have a super chip giving me a code of 1316 I dont have scanner to do buzz test, I know it could be uvch loose. However I talked to superchip and they said that my chip is obsolete and I should remove it as it may have gone bad and if so will yield this type of idling. So question do where do I find the superchip to remove from the PCM or where is PCM on 2002 F250 7.3 thanks
Old Oct 2, 2012 | 05:41 PM
mikeismadness's Avatar
mikeismadness
Without the programmer that downloaded the program its stuck I believe
Old Oct 3, 2012 | 07:39 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
He might have a Superchip that is plugged into the diagnostic post on the back of the PCM.
Not sure about the diesels, but on the gassers, the PCM is on the firewall, above the driver's left foot.
Old Oct 3, 2012 | 09:10 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I'm not understanding what you are saying. Do you have the programmer or an actual chip on the PCM? What are you reading the codes with?
Am I missing something here?
Old Oct 3, 2012 | 11:22 AM
SuperDutyScaler's Avatar
SuperDutyScaler
i didn't know Super chip sold plug in chips for diesel? i thought they were for the gas trucks only? And my old 1997 F250 HD had a Super chip chip plugged into the pcm and it did the same thing your experiencing, after many trips to the service shop one tech finally just unplugged the chip and the truck ran beautiful again, turns out the chip had a short and was causing all my problems
Old Oct 3, 2012 | 11:06 PM
blm250's Avatar
blm250
thanks to all, I feel like an idiot I have a superchip scanner . I have had this truck for 6 years never used it just assumed I had chip I pulled the PCM out no chip set back to factory default with superchip scanner / tuning tool. I still am having misfire at low rpm engine light will come on briefly no codes not sure what is going on new icp could it be air in hpop rails I really dont want to pull vc yet if there are other things I should check any ideas will help thanks
tjbradney
Apr 16, 2016 02:59 PM
lordtavo
26
Nov 16, 2015 06:10 PM
bill wilson
Mar 28, 2015 04:04 PM
reality_check
Apr 18, 2013 11:31 PM
edub32
Jun 30, 2010 07:17 PM
