TS chip can't start
Old Apr 15, 2016 | 07:17 PM
tjbradney's Avatar
tjbradney
TS chip can't start
Well I just had a new pcm installed. Figured I'd quickly reinstall my TS chip. Well I was wrong . I can't get the pcm out of the truck like before . I unscrewed the 10mm bolt under the hood. And all the stuff holding the pcm in. I ended up pulling as hard as I could it pulled the rubber grommet that the wiring and all goes through but Pcm is still connected to . I can't figure it out how to get those two things apart so I said screw it and tried to get the wax layer off the connectors didn't seem to have any so I used a scotch pad to clean it and it seems to be clean enough but once it's all plugged in an all I have just cranking. So i took the chip off and just plugged the pcm in and it starts. So maybe it's not clean enough on the connecting spot?
Old Apr 16, 2016 | 10:05 AM
Themoose56's Avatar
Themoose56
Either the connection isn't clean enough or...the TS chip will have to get re-calbrated to your new PCM, when I got my chip I had to send in the code off my PCM...
Old Apr 16, 2016 | 02:12 PM
coax9952's Avatar
coax9952
You have to have the chip reburned to the new PCM code
Old Apr 16, 2016 | 02:57 PM
tjbradney's Avatar
tjbradney
I have the connections cleaned like before even looked up the dp chip instructions and my board looks just like that one . But my guess is it's the code. I never sent in my pcm code guess I got lucky when I bought it from xdp. But my code is abj0 on this new Pcm and my paper work from swamps said the chip was programmed for a pmt but idk what my previous one was
Old Apr 16, 2016 | 02:59 PM
tjbradney's Avatar
tjbradney
👍👍. What I figured didn't click to I had the bed pcm cleaned and it just wouldn't start but I emailed swamps but in also considering a sct live wire. Only concern is it plugs into the obd2 port? All the time? My concern is I know when I go to scan my truck if it's running and I hook up it shuts the truck off and won't start till its unhooked
Cduff
Computer Chips & Tuners
Dec 8, 2015 04:39 PM
bill wilson
Mar 28, 2015 04:04 PM
snakedoc
Ford Truck Parts for Sale
Sep 30, 2012 12:13 PM
papadelogan
13
Dec 10, 2009 08:41 AM
foxracing0934
Jul 2, 2009 05:12 PM
