2002 Explorer wont start
Old Sep 30, 2012 | 08:55 PM
rkstengel's Avatar
rkstengel
It turns over but just wont kick in. battery good, fuel pump good, no check engine light. It did this a couple time this month, and finally started, not it wont start at all. Runs great otherwise without any issues. Just dont know where to look or what to look for. All fuses are good. Fuel pump safety is okay.
Old Oct 1, 2012 | 06:39 AM
shorod's Avatar
shorod
Welcome to the forum!
For starters, which engine does your Explorer have? How do you know the fuel pump is good, did you check the fuel pressure at the fuel rail? Have you checked for spark?
When you state, "turns over but just wont kick in" I interpret this to mean the starter motor is spinning the engine over (belt is turning) but the engine doesn't fire and start, as opposed to the starter motor is spinning but never engaging the flywheel. Is that correct?
-Rod
seanm
Jan 2, 2008 11:11 AM
oojbearoo
Feb 2, 2007 03:42 AM
lizziesmom902
Oct 21, 2004 09:26 PM
ford ex nz
Nov 11, 2003 07:00 PM
cobra413
Jul 5, 2003 08:29 AM
