removing the ipr
Oct 1, 2012 | 12:23 PM
Tin nut is 3/4 I think. DON'T overtighten the tin nut on re-install. My 1 1/8 craftsman deepwell works just fine, and didn't cost 40 bucks.
Oct 1, 2012 | 08:42 PM
Stupid tin nut, does it have something to do with the magnetism or electric current?
Oct 2, 2012 | 11:48 AM
Oct 2, 2012 | 12:03 PM
Quote:
Originally Posted by
427 fordman
Yes the nut is 3/4". Also for the IPR you can use a 1/2" drive deep 6 point 29mm
PS, I the IPR is out, shouldnt you disamble it and clean any debris there?; they have been known to become sticky if debris enters the valve.
As you have e-fuel and not bowl, also you can fab a tool like this:
Oct 2, 2012 | 12:08 PM
just getting started and having a hard time with the plug at the top of the res.....is it supposed to be VERY tight. i dont want to strip it. im using a 3/16 allen.
Oct 2, 2012 | 12:24 PM
kupiec20
I really dont know, I havent worked with that plug, but maybe its VERY tight. I have read that you can remove the sensor of the reservoir if the plug is frozen and from there empty the reservoir. IDK. Good luck.
Oct 2, 2012 | 07:31 PM
3/16 is right. Try tapping the drive in first with a hammer so its firmly seated and that will reduce the blowout probability and add a boxwrench at the end of the ratchet handle to increase the torque as you undo it.
Oct 2, 2012 | 07:36 PM
thanks.... but what if i do blow it out!?
Oct 2, 2012 | 07:43 PM
kupiec20
If you are afraid and dont want to unplug the sensor, just pull out the IPR and put a lot of rags to stop or catch the oil. But you will have to fill it up later, so
Oct 2, 2012 | 07:44 PM
kupiec20
Mine got all jacked up on my 17* HPOP install, but we got it out with an easy out. Ordered a new one from diesel o rings. Just go slow and be careful.
Oct 2, 2012 | 07:51 PM
if i just pull the ipr how do i get oil back up into the res.?
Oct 2, 2012 | 07:55 PM
kupiec20
Throught the hole of the sensor I guess.
Oct 2, 2012 | 07:56 PM
kupiec20
You're over thinking this. Did you strip the HPOP plug?
Oct 2, 2012 | 08:04 PM
not stritted yet but ill ge back to all if i do
Oct 2, 2012 | 08:11 PM
kupiec20
There you go. Just get in there and do it!
