hazzards stop working w/brake applied
Old Oct 12, 2012 | 02:13 PM
  #31
jeff14346's Avatar
jeff14346
Mike
from laying on my back under the dash, it does look like the part you have displayed, vehicle is basic, only power is brakes and steering. Oh well, eventually I will get it figured out, if it has tatas or tires, will give you problems!!
Thanks for all the head banging, careful pulling the splinters out
Old Oct 13, 2012 | 08:48 PM
  #32
jeff14346's Avatar
jeff14346
little update action
the new to me used turn signal switch is bad, removed from column, had a right turn on, as I was moing switch all of a sudden turn signal would work then stop, something FUBAR in the switch, went to Orielly, new one will be here tomorrow then reassemble and drive!!! Then onto my next problem-fix of leaking steering gear box
Old Oct 17, 2012 | 08:37 PM
  #33
jeff14346's Avatar
jeff14346
update
installed brand new switch, got nothing, only thing working is horn and running lights, no hazzards, not turn signals. WTF, reconnected old switch, have nothing. checked all fuses under the dash, all are good.
fishing for ideas? does the solenoid power side with the fusable links possibly play into effect for this problem?
thanks
Jeff
Old Oct 18, 2012 | 09:11 PM
  #34
jeff14346's Avatar
jeff14346
throw your 2 cents in on ideas!! double checked color of wires, all is install correctly, have not had time to investigate further do to newborn in the house
Thanks
Jeff
Old Oct 19, 2012 | 03:43 PM
  #35
jeff14346's Avatar
jeff14346
Fixed!!! the pos
Old Oct 19, 2012 | 03:54 PM
  #36
mikeo0o0o0's Avatar
mikeo0o0o0
Congratulations! What was causing the problem?
Old Oct 19, 2012 | 06:05 PM
  #37
jeff14346's Avatar
jeff14346
the dumb goof turning the wrenches
2 blown fuses, when I was checkin fuses with test light it lit up, didntg dawn on me to check both sides of the fuse with the tester
Old Oct 19, 2012 | 06:08 PM
  #38
mikeo0o0o0's Avatar
mikeo0o0o0
Hey, don't feel bad. Been there, done that.
jpeckham
Electrical Systems/Wiring
Mar 8, 2013 11:48 AM
MTrumpy
Aug 27, 2007 12:09 AM
kermmydog
Nov 12, 2006 11:34 PM
b_dub
18
Dec 4, 2003 07:36 PM
dehamma
Jun 26, 2003 10:33 AM
