How-To on replacing ABS sensor
Old Jun 11, 2017 | 02:09 PM
Apocalypse's Avatar
Apocalypse
Did this the other day and thought it was time to post it up
Old Jun 11, 2017 | 05:15 PM
WE3ZS's Avatar
WE3ZS
Jonathan, I know that you know that you should be using jackstands, so I won't mention that.
Did you grease the unit bearing while you had the ABS sensor out?
Old Jun 12, 2017 | 01:12 AM
Apocalypse's Avatar
Apocalypse
Yes? Seriously though I have no idea what I was supposed to grease
Old Jun 12, 2017 | 02:05 AM
WE3ZS's Avatar
WE3ZS
Don't you have one of Snowseeker's unit bearing grease fittings? Or the more expensive one from Riff Raff? My bearings each took about 22 to 24 full pumps of grease when I did mine. The fitting goes into the hole where the ABS sensor goes, then it's just a matter of hooking the grease gun up to the special fitting's zerk and pumping it full as you spin the hub.
I have two of the fittings if you need/want to borrow one.
Old Jun 12, 2017 | 09:51 AM
ExxWhy's Avatar
ExxWhy
Score one for the simplicity of 2WD. Don't even have to jack it up or take the wheel off. Thanks for sharing.
Old Jun 12, 2017 | 07:00 PM
Apocalypse's Avatar
Apocalypse
I have 2 of them as well lol. I totally forgot about it though
MattyP10178
Dec 5, 2016 11:45 AM
Dstosh
Aug 7, 2016 08:44 AM
broknsmokey
May 7, 2016 01:04 PM
broknsmokey
May 6, 2016 11:00 AM
crop harvester
May 28, 2013 10:03 PM
