6637 Filter Test
Old Sep 29, 2012 | 06:49 PM
  #31
oldbird1965's Avatar
oldbird1965
Good point Mike! I read on here someplace one of the members uses the used filter in his shop vac.!
Old Sep 29, 2012 | 07:36 PM
  #32
fordpride's Avatar
fordpride
I guess I'm just very **** retentive about simple maintenance and it bugs the hell out of me when people go cheap on things that's already cheap
Old Sep 29, 2012 | 07:37 PM
  #33
fordpride's Avatar
fordpride
I have my old 6637 I'm gonna see if it fits my shop vac
Old Sep 29, 2012 | 07:38 PM
  #34
fordman67's Avatar
fordman67
Especially on basic easy things like this
Old Sep 29, 2012 | 07:56 PM
  #35
oldbird1965
Well, I've never have done that either, I just throw it away. Before I take off Thur or Fri I'm changing mine out, oil too!! I carry all that stuff with me, time to use it.
Old Sep 30, 2012 | 11:18 AM
  #36
Talyn's Avatar
Talyn
It's not really being cheap for me, but then I don't have the extra 30 dollars right now either.
When you start to twist and contort a filter, you will damage it though. That will create gaps in the medium.
I just wack mine on the cement to dislodge the big stuff and throw it back in when I'm done.
I've done the other things I've mentioned before and had no issues with the filter. I probably made it more restrictive washing it.
I spend time playing and testing things out.
The only way your going to hurt these trucks turbo wise is putting a **** filter in there or running no filter.
The chances of you damaging these filters and getting enough dust/sand though to damage anything is slim unless your driving out in the desert.
Old Oct 1, 2012 | 08:03 AM
  #37
Awitte58's Avatar
Awitte58
I understand the idea now. Thanks Talyn.
I figured it was something along the lines of 'dirt in the filter stops more dirt from getting through'
Makes sense to me, but im like Mike. Basic maintenance im ****...I keep an excel file of EVERYTHING I have ever done to the truck.. the date it was done, mileage, where i purchased stuff... etc
Every detail about it, and for $23 (bought a few during clays group buy) I wont even spend the 15 mins doing that. lol
Old Oct 1, 2012 | 08:52 AM
  #38
DIYMechanic's Avatar
DIYMechanic
I don't mean to hijack the thread (although that is our specialty here in OBS PSD land) but there is a great app that I use on my phone for this too. It's called aCar. I paid a little for the full version so I could back up my data, but the free version works just as well. It will track mileage (you enter your fill-ups and odo reading), running costs, oprating costs per day or per mile, all your maintenance, etc. You can even set alerts based upon the mileage or date and it will remind you of services that are coming due. It really is a powerful app. I use an Android, but I think it is available for iPhone too. It's good stuff. And, no I don't get a commission for their sales, lol. It's just a nice tool that I thought I might share.
Old Oct 1, 2012 | 09:08 AM
  #39
Awitte58's Avatar
Awitte58
I like that hijack! thanks nate.
i have other friends who track date, # of gallons, place, price per gallon at every fill up in a little journal.
He could tell you what he paid for his first tank of diesel in that thing! I never bothered with it THAT much, but an ap would certainly make it easier than sitting at a pump another 5 mins. lol
I use android too. This is good.
aCar...gunna search it now.
Old Oct 1, 2012 | 09:31 AM
  #40
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
https://www.ford-trucks.com/forums/8...y-filters.html
Old Oct 1, 2012 | 10:15 AM
  #41
Talyn's Avatar
Talyn
I've met people who will replace every light on their vehicle if one goes out.
All depends on how much money you have sitting around to spend on it.
I've seen people who religiously spend time maintaining their vehicle and are always having problems, and then you see people who rarely change their oil or do any maintenance and wonder how their vehicle is still running so well.
I try not to over do it.
Just like the guy who over cleans his gun throws it out of tolerance or wears away the protective coatings.
Yes, you can over clean your gun and screw it up.
Old Oct 1, 2012 | 12:55 PM
  #42
DIYMechanic
I don't get it. Are they using the filter in conjunction with the existing filter on the shop vac? It sounds like they are using this one INSTEAD of the one inside the shop vac. Wouldn't that run all that dirt through the motor on the shop vac and just plug up the INSIDE of the tymar?
Unless I am completely missing the point of how they did that it sounds to me like that would be the case.
Old Oct 2, 2012 | 11:57 AM
  #43
Awitte58's Avatar
Awitte58
I believe they take the factory one off and are mocking up the 6637 over it.
If their shop vacs are anything like mine. you can remove the top...and the filter is in the center. The end of the 6637 is big enough in diameter to slide over the filter location.
Ill try it...
Old Oct 2, 2012 | 01:00 PM
  #44
DIYMechanic
It sounds to me like they're saying you just remove the original filter (inside the
"hopper") and put the 6637 on the EXHAUST port (outside the unit).
Old Oct 2, 2012 | 09:27 PM
  #45
oldbird1965
No, I think you remove the vac filter and mod the 6637 to go where the vac filter was.
