Well I had a Fireturd many moons ago have a coil just crap out. I was driving along and it quit running, I managed to run 2 stop signs and coast home, so it happens, on a Taurus not so sure. do you have a cheapo spark checker?
since you have no spark I would start there. Not sure how this computer works but most in cars control the ground side so you may be on the right track.
I guess I would check the ground wire from the coil to the pcm, if you really want to be sure it is good I would take a headlight bulb and put power through the wire, sometimes it will ohm check good (static) but with a load (dynamic) it has too much resistance. Thats if you have the time to fart with it.
