weak spark
Old Jan 12, 2006 | 09:23 PM
freejay's Avatar
freejay
weak spark
I have a 96 F150 with a 5.0L It has a very weak spark right at the coil, not even enough to show anything through the coil wire. The coil has over 10 volts going to it while cranking. Is the coil shot?
Old Jan 13, 2006 | 10:04 PM
freejay's Avatar
freejay
Ok so it was the coil. Just in case somebody asks in the future
Old Jan 14, 2006 | 02:36 PM
TigerDan's Avatar
TigerDan
Thanks for the update. Did you test the coil to determine the problem, or just went ahead and replaced it and found the cure that way?
Old Jan 15, 2006 | 09:02 AM
freejay's Avatar
freejay
I wanted to test it but I didn't have any specs. So I just put a new one on and that made all the difference. The spark at the coil will jump about 1/2" , before it would not even jump 1/8"
