Sponsored by: Real Truck
V10 engine builders
Old Sep 29, 2012 | 10:52 AM
dkf's Avatar
dkf
The engine may be able to handle 5w-50 especially if the truck sees all warm climate temps. The supercharged 5.4l in the Shelby mustang specs 5w50 from the factory however that vehicle obviously sees different use. The guy at that works at the Cleveland block plant said they do testing with 5w-40 without issue. I ran 5w-20 in mine until the warrenty was out then switched to 5w-30. The V10 speced 5w-30 originally. IMO I would stick with a 5w-- for sure. I would rather run a 5w40 than a 5w50 though.
Old Sep 29, 2012 | 05:08 PM
brian.hill4's Avatar
brian.hill4
No offense taken. I'll give it a go.
Old Oct 1, 2012 | 01:54 AM
bogeyjoe's Avatar
bogeyjoe
I came to this thread because I am looking to replace my Isuzu Diesel engine/ boat anchor with a V10 (that I'll eventually convert to run Bi fuel with LPG) and am thinking you're pickin at Brian over what oil he uses to the extreme. I may not be the one to brag since my engine all but threw a rod after floating out my valvetrain down a hill, which broke my rocker arm forcing my push rod up through my valve cover. The engine now runs on 5 instead of 6 cylinders so the fuel seeps past the piston and into the crankcase, which turns my three gallons of 15w40 into four gallons of 1w2 within 100 miles. I've been driving it like that for 900 miles (she runs a little rough) so I can't imagine being one class of oil away from recommended doing any "damage" to his engine. Its going to push through all the galleys just fine, I'd think.
Old Oct 1, 2012 | 06:57 PM
brian.hill4
Thanks BogeyJoe. I can handle the criticism. One way we learn is to find out what doesn't work.
Old Oct 21, 2012 | 05:47 PM
Bruno Senff's Avatar
Bruno Senff
Hi I live in Brazil and I need to buy a V10 engine ford full ... So far I have not found. Can anyone guide me ... My motor does not recover here, porting will buy the most modern, year 2006 forward, where do I find one of these in the box complete with all accessories? I could send the U.S. deliver al the home of a friend who is in charge of dispatching him here for my country. Thank you.
pamante
Modular V10 (6.8l)
Jan 22, 2017 08:37 PM
dtherrien
Sep 22, 2016 09:04 PM
carprojects
Modular V10 (6.8l)
13
Dec 24, 2010 04:58 PM
carprojects
Dec 15, 2010 03:03 PM
glcarpe
Mar 19, 2006 02:05 PM
