truck overheating
Old Sep 27, 2012 | 03:42 PM
alexisvfd's Avatar
alexisvfd
truck overheating
i have a 03 7.3 dually and when im going up hill pulling my at&t tractor whick only weighs 3,000 plus trailer the transmission overheats and i have to pull over to let it cool off..is that normal
Old Sep 27, 2012 | 04:39 PM
nlemerise's Avatar
nlemerise
No that is NOT normal IF you are moving along at highway speed. If you are crawling along due to a bad road/dirt road/steep incline, it is normal and that is why nearly everyone upgrades the tranny cooling system.
Old Sep 27, 2012 | 04:52 PM
guitarpicr's Avatar
guitarpicr
pulling 3 k should be a walk in the park for your truck- Could the trans cooler bypass valve be stuck closed ?Edit - Just asking about this as I thought I remember reading about a bypass valve in the line but not positive it. To op - Do a search for clogged trans cooler & read Mark Kovalsky' posts- He is the Ford trans expert on the site.
Old Sep 27, 2012 | 05:27 PM
alexisvfd's Avatar
alexisvfd
yea i cant get up to speed going up the mountain so im going about 30mph and just overheats ill check that
Old Sep 27, 2012 | 05:46 PM
Bonanza35's Avatar
Bonanza35
It normal if the torq convertor isn't locked. I had this problem and didn't know it till I put on a good gauge. At 20 degrees outside slow up switch backs no trailer my trans use to get up to 220. So pulling a trailer its going to be hot. Change the trans cooler and get some tunes that helps the trans shifting and lockup. If you don't you will replace your trans sooner then later.
Chet
Old Sep 27, 2012 | 11:26 PM
1fixitman's Avatar
1fixitman
You also might consider taking a water hose to your radiator(on the outside) and cleaning it and then follow it up with compressed air to clean the heat exchanger on the outside of the radiator. This is best done with the intercooler out of the truck. My intercooler, radiator and ac condenser were hammered with clay dust and tiny pebbles from the Prev Owner/s.
Best to add an additional transmission cooler and to verify that you have flow from your transmission to your radiator. One guy recently purchased a Heavy duty transmission cooler from Orilley's for his truck. I have a manual transmission so I don't have these issues for most of my driving.
Dwayne
Dwayne
Old Sep 27, 2012 | 11:46 PM
h2guy's Avatar
h2guy
Before spending $$$ on this "problem", when you again attack this hill, pull the shift lever down into "second" (2), to ensure the TC is gonna be locked, and then see if it still over heats at the 30 mph speed.
Should lessen it. If it does, then the unlocked TC was the cause.
Liquid10Rider
Aug 8, 2017 10:29 AM
Bubba828
Apr 9, 2009 09:43 AM
hotrod 250
Jun 10, 2008 09:37 AM
01lariat
Nov 15, 2006 02:45 PM
turboale
May 3, 2006 12:12 PM
