I have had my gauges for a little while now.i dont flog my truck as a general rule.up until last night i had only seen 15lbs and lately not been able to get that.
well last night i had to run toget more paint for new bays room.
well this chick in a bronco cut me off......soooo at the next light i was next to her...and wound up for her cutting me off for no reason....so i have the, flogging molly pedal down at the first sight of green...next thing i know she was on a tear and i look up and low and behold she is making twenty pounds! I cant believe it.i d idnt think these trucks made that much stock...wow.
Never knew what mine got stock due to up pipes leaking, but 15-17 is normal. As Eric Joseph and said, if everything is just right with the truck, you ate your wheaties, and got a little road rage going on, im sure it could get that 20 every now and then!
