Another battery light flickering problem!
Old Sep 26, 2012 | 07:57 PM
chowda633's Avatar
chowda633
Seen a million posts with these lol. First time for me it was the alt. Put a new alt in from auto-zone. Not sure if its a reman looks brand new with a warranty.
That was only 3 weeks ago. It got 2 brand new batteries in the last month as well. I did the heater plug delete and the wires just hang. Looked like the positive wire was leaning against a bolt tonight so I moved it not sure if it fixed it.
Problem is that randomly a few days ago while driving the battery light started to flicker slightly no loss of power or anything. It pretty much does it only when I am on the gas or the cruise control is on. When I let off it shuts off again. VERY intermittent. Did it at idle earlier today. Instead of turning off when you hit the gas (Bad alt) It comes on! Wtf!?!
Any help appreciated!
Thanks,
Josh
Old Sep 26, 2012 | 08:02 PM
BigAlsPSD's Avatar
BigAlsPSD
Make sure that the small plug is fully seated and in good condition on the alternator, check connections of the larger lug, beyond that I would have the alternator bench tested.
Old Sep 26, 2012 | 08:04 PM
chowda633's Avatar
chowda633
Checked both both solid.
Old Sep 26, 2012 | 08:26 PM
1fixitman's Avatar
1fixitman
Tape that wire from the AIH up and put some heat shrink on it.
Dwayne
Old Sep 27, 2012 | 01:52 AM
Lineman85's Avatar
Lineman85
had the same problem changed both my alternators( came from the facory with 2 and 2 ) light stopped flickering
Old Sep 27, 2012 | 03:32 AM
Stewart_H's Avatar
Stewart_H
Get one of these and plug it in your cig lighter.
See this thread by Greg: https://www.ford-trucks.com/forums/1...l#post10806422
Stewart
Old Sep 27, 2012 | 06:26 PM
chowda633's Avatar
chowda633
Ha thanks! As soon as i saw that i plugged in my tuner and looked at battery voltage its only getting between 12-13v most of the time!
patrickg450
Jul 10, 2016 07:58 AM
99F350bigorange
Sep 24, 2013 10:24 PM
medic25
Dec 10, 2012 11:24 AM
FoundOnRoadDriving85
Jun 18, 2011 12:26 PM
Dirtmetal
Mar 28, 2011 06:21 PM
