My 2002 superduty diesel 4x4 had the ac fan switch (4 position) quit. Only works on high. Is it the switch or is this a sign that the ac is low on charge?
It's most likely the blower motor resistor. It is located on the firewall by the blower motor, it's red and white with a connector going to it. Mine was bad when i got my truck. The new part from ford was like $22.
It was the resistor pack. A real bugger to get out as the main power lead in the plug welded itself to the resistor. $23 for the resistor and $15 for a new plug and all is well. Thanks!!!
