Starting the sheetmetal work
Old Sep 28, 2012 | 07:52 PM
AXracer's Avatar
AXracer
Anyone read my welding lessons? Indy are you getting penetration or are the beads just sitting on top the metal? I highly recommend you use 0.025 ESAB Spoolarc Easy Grind wire for sheetmetal work.
Old Sep 29, 2012 | 09:08 AM
Indybeer's Avatar
Indybeer
I am getting good penetration...could be a little more...will have to keep playing with power setting to get it dialed in.
I have been reading your tutorial and have found it very useful! Thanks
Old Sep 29, 2012 | 09:39 AM
AXracer's Avatar
AXracer
Use the power and wire feed speed setting recommended for the metal thickness on the machine, not more than one metal thickness setting to either side and vary the wire stick out (1/4 -3/8" is ideal, never more than 3/4") and torch movement speed to adjust penetration. Butt seams should be tight together, never wider than the filler wire diameter. Using a copper or aluminum backer pressed tight to reduce blow thru. Filler wire should not be thicker than the metal.
rsh1966
18
Jul 4, 2018 07:12 PM
Indybeer
13
Aug 30, 2012 07:54 AM
19fifty4
15
Oct 2, 2008 02:07 PM
codys50ford
Oct 1, 2007 10:40 AM
jack71
Jan 29, 2006 06:54 PM
