This would make it easier for my build if it doesn't create a pressure drop or restriction. What do you guys think? Im using a super duty pump just so you know.
you will need a filter after the pump in case the fuel pump self destructs or has metal shaving from it the sd has a screen filter before in tank and filter after pump on the engine also there wont be a restriction if you have the filter after the pump unless the filter is plugged up
i have it set up like this
90 gal tank filter pump filter engine
at wot i have no pressure drop none at all all my lines are 3/8s from tank to engine the pick up is 1/2 inch
