Sponsored by: Auxito
2000 E250 van
Old Sep 24, 2012 | 09:01 AM
stewde's Avatar
stewde
Question 2000 E250 van
I have a e250 van with V6 which has service engine soon light on. Light came on after transmission rebuild. Computer says left & right bank to lean. I have replaced oxygen sensors, PVC valve, plug wires and coil pack. I'm getting great gas milage and the engine runs great even with 260+ thousand miles. The problem is at idle and not all the time, the engine acts like it looses 2 cylinders, it has stalled once but acts like it wants to stall when it happens. It does not happen all the time and only at idle once I hit the gas the thing runs perfectly smooth. Any help would be great.
Thanks in advance
Old Oct 1, 2012 | 01:09 PM
stewde's Avatar
stewde
OK now I've replaced the IOC and still have the same problem at idle, it actually stalled out on me after IOC was replaced which did not happen before. Seem with each thing replaced the idle problem becomes worse. Whats left to replace?
Old Oct 1, 2012 | 03:46 PM
projectSHO89's Avatar
projectSHO89
You probably have an intake vacuum leak.
Old Oct 2, 2012 | 11:25 AM
stewde's Avatar
stewde
thanks for the advise, anybody know where I can find a diagram of the vacume lines? It's kind of hard to see everything the way the engine is stuffed in.
Old Oct 2, 2012 | 03:27 PM
Torky2's Avatar
Torky2
Why not post in the forum that is FOR full-sized vans? They are much more likely to have a van vac diagram than people here on an F-150 forum.
On the index page here:
Ford Truck Enthusiasts Forums - Ford truck and SUV owners and enthusiasts Community And Information Source.
Go down to the 6th heading "Other Fords", and the 2nd forum under it is "1968 - Present Full Sized Vans". That is where the van people hang out.
Old Oct 2, 2012 | 03:38 PM
stewde's Avatar
stewde
Thank you and sorry about that!
Old Oct 2, 2012 | 05:51 PM
stewde's Avatar
stewde
Well found a big problem, after taking off the air cleaner and cleaning the air sendor and other stuff I went to start the van and it cranked over and I heard a clunk, stopped and took a look and found the harmonic balancer laying on the frame. The bolt sheared off, NICE Looked like the bolt had broken off a while ago and luckly the thing waited to fall off while in the drive way of my shop. I'll bet it will run better with the balancer back on and hope that is was the cause of my rough idle but probably not.
dmikel
Large Truck
Nov 3, 2011 09:55 PM
jackone
Dec 10, 2008 12:59 PM
tored1971
Mar 24, 2008 10:31 AM
jasonspruill
Aerostar
Nov 6, 2004 02:15 AM
greglewis
Nov 23, 2000 10:48 AM
