Sponsored by: Real Truck
Cutting off at idle
Old Nov 6, 2000 | 02:19 PM
greglewis's Avatar
greglewis
Cutting off at idle
I have a 1999 E-350 5.4L that won't idle when you first start up. If you drive for a while 15 or 20 minutes you can hear the engine pick up RPMs at idle and it will do fine. Until that point you have to keep one foot on the brake and one on the gas at stoplights so that it won't cut off. Once it finally cuts in it idles perfectly until you cut the engine off. If it sits for an hour or more the cycle starts all over again. What gives????????
Old Nov 6, 2000 | 11:56 PM
spaceace's Avatar
spaceace
Cutting off at idle
idle air bypass valve
Old Nov 7, 2000 | 04:28 AM
mikerich's Avatar
mikerich
Cutting off at idle
had same problem on V-10, definetly idle air valve
Old Nov 7, 2000 | 08:36 AM
greglewis's Avatar
greglewis
Cutting off at idle
Thank you. Was that a dealer item or can that be done at a "normal" garage?
Old Nov 7, 2000 | 07:23 PM
J.C.'s Avatar
J.C.
Cutting off at idle
Any garage can change it. The one on my truck was acting up and I was just going to change it myself but, the only place that had one was the dealer and they gave me a price of $80-90 for one. I said forget that and ended up taking it to the dealer so they could do it under warranty. Only problem is it never leaves any error codes and the dealer could never get it to act up so, I ended up having to take it back three times before they just said to he** with it and just changed it. The correct name for the thing is the idle air control valve (IAC) but, it is refered to as an air bypass valve on other cars. I'm not sure if there's really any difference other than the name.
Old Nov 8, 2000 | 04:38 AM
mikerich's Avatar
mikerich
Cutting off at idle
not sure, mine was done under warranty after taking to dealer 8 times for same problem, i found what the problem was by using this site. I don;t beleive its an expensive dealer installed item though. good luck
Old Nov 8, 2000 | 12:25 PM
greglewis's Avatar
greglewis
Cutting off at idle
Thank you all for you assistance. Things have gotten worse since I first mailed as now it cuts off as soon as you let off the gas and won't idle ever. I will take it in next week.
Old Nov 8, 2000 | 12:36 PM
greglewis's Avatar
greglewis
Cutting off at idle
Thank you for the help. The situation has gotten much worse as it now cuts off whenever I take my foot off the gas. I am taking it in next week.
Old Nov 21, 2000 | 09:16 AM
greglewis's Avatar
greglewis
Cutting off at idle
I took my van in to have it fixed and of course they charged me a $65 diagnostics fee but the good news is that it was definately the IABV. Total bill was $285 but the van is running better than new. They flushed the computer and let it relearn everything. Thank you again for your help.
Old Nov 22, 2000 | 12:49 AM
fishinbum's Avatar
fishinbum
Cutting off at idle
They charged you a $65.00 diagnostic fee? Being the van is only a year old I would think all charges to be covered under factory warranty.
Old Nov 22, 2000 | 08:12 AM
greglewis's Avatar
greglewis
Cutting off at idle
Unfortunately the van now has 68,000 miles on it. My wife and I show English Bulldogs on the dog show circuit and we do ALOT of traveling.
Old Nov 23, 2000 | 10:48 AM
fjlee's Avatar
fjlee
Cutting off at idle
styleside96
1997 - 2003 F150
Nov 19, 2012 09:37 AM
montgomery7
Feb 14, 2010 10:39 PM
AndysFords
Jun 15, 2006 02:23 PM
simms63ss
May 8, 2005 02:21 PM
Tony G
Jul 18, 2004 12:53 PM
