BLOCK PLATE HELP
Old 09-21-2012, 06:59 PM
plsix's Avatar
plsix
plsix is offline
BLOCK PLATE HELP
Does anybody here have a block plate for a 400 with a c6.
Need to get the trans swap finished.
Also, is there an inspection plate as well or does the block plate cover everything and you just use the starter hole for inspection. I also am using a front sump oil pan if that matters at all.
thanks
Old 09-21-2012, 07:17 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
There is a small inspection plate at the bottom so you can put the torque converter bolts in.
underthebridgejim
27
02-26-2014 07:52 PM
underthebridgejim
42
01-24-2014 12:01 AM
plsix
09-22-2012 10:20 AM
mmuenchow
04-13-2009 08:15 PM
Quick Reply: BLOCK PLATE HELP
