Importance of a block plate?
This may sound like a rookie mistake and it is, but during the process of replacing trannys, it wasn't until I got everything clean and shinny, that I noticed the gap between the flywheel inspection cover, and the top of the bell housing & block. I didn't notice B4 when everything was old and dirty, so I just once again reassembled the way the PO had had it. Ok what I would like to know is the importance of a block plate ( I thought they were for starter support on certain applications). I now realize they are designed to keep debris out of the flex plate, starter, and torque converter. Do I "A" need to pull back the trans. to install one, "B" Fab a piece to cover exposed area until the next time I pull the trans., or "C" can I just leave it as is with just a inspection cover. Pro's & Con's welcome.
Jim,
Unfortunately I think I too would also recommend to install the block plate. Its one of those Ford better ideas and like Scott said, the clearances were designed to have the thickness of that plate in there. On GM applications that bellhousings bolt directly to the engine blocks and there is no block plate. GM used a dust shield to cover the lower exposed portion of the flywheel. Some of the 4x4 applications had a pretty substantial aluminum dust shield with some extra bracketry.
But for Ford applications I'm pretty sure that block plate is an important part.
By that way, and, I know this is going to sound a little strange.......but....your bottom end looks great! Thats a great looking oil pan.
Bobby
Bobby
Scott, Moe, and Bobby, thank you for your responses, they are very appreciated. I just ordered a block plate from Summitt , its from "Performance Automatic" (#PA26445). I do want everything on this truck as right as I am capable making it. So with that said the easy part is done, now all I need to do is muster up the motivation to get back under the truck, and loosen that trans one more time. Im not quite sure when that will be , but I'll post it when I do. LOL (Go 49ers)
Jim,
I feel for you. After all the issues you had with the tranny its got to be a little frustrating to have to dive back in there and pull it again.
You might be able to sneak the block plate in there without having to drop the tranny all the way out. I've replaced several flywheels on a variety of vehicles without dropping the trans. Might be a bit tougher with the block plate though.
Good luck with it. You'll get there
Bobby
Bobby
I was just doing some internet research on how to install the block plate, and I have another question. As I understand it, the plate goes between the block and the flexplate and has its own 2 bolt holes to secure it to the block? If this is correct I'll need to separate trans from block while unbolting TQ. Con., remove flexplate, bolt plate to block, reinstall flexplate, slide trans back into position re securing TQ. Con., re bolt trans to block. Doe's that sound about right, besides D.S., shift linkage, and cooler ines?
