BLOCK PLATE HELP
Does anybody here have a block plate for a 400 with a c6.
Need to get the trans swap finished. Also, is there an inspection plate as well or does the block plate cover everything and you just use the starter hole for inspection. I also am using a front sump oil pan if that matters at all. thanks |
There is a small inspection plate at the bottom so you can put the torque converter bolts in.
