F-250 won't run. Help!
Old 09-21-2012, 12:49 PM
Robby Nash's Avatar
Robby Nash
Robby Nash is offline
I have an 04 F-250 6.0. The truck will start then die after about 3 min of running. Truck has a new battery and alternator. I ran an OBD test on it and these are the codes im getting. P0118 engine coolant temp, PO198 oil temp, P2285 ICP sensor. I dont know what to think. Help!
Old 09-21-2012, 02:30 PM
Tom's Avatar
Tom
Tom is online now
Hi Robby, I'm going to send this one down to the 6.0L forum. They'll be better able to help you down there.
Old 09-21-2012, 08:10 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Try unplugging ICP and see if it will start. PCM will default to a value that will allow truck to start. IF it starts ICP or wiring harness (pigtail) is bad. If not it could be one or more of many things. On early '04 truck ICP is under/behind turbo. On late '04 and newer trucks it's in the passenger side valve cover.
Also check the no start thread in the Tech folder....
Old 09-22-2012, 08:40 AM
cheezit's Avatar
cheezit
cheezit is offline
pretty much right on. possibly shorting v-vref
Old 09-22-2012, 06:40 PM
bismic's Avatar
bismic
bismic is online now
Received 2,522 Likes on 1,754 Posts
Look over the wiring to your EOT real carefully also.
Old 09-22-2012, 10:18 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
my bet on a Bad wire Harness not at the pigtail either somewhere From PCM to the middle Messing with all 3 sensors
All 3 DTC was short circut codes
Tcs60
06-05-2017 06:50 AM
chadjetlag
10-24-2015 10:21 AM
tcjhkbjt
10-28-2013 12:54 PM
lhuninghake
09-09-2008 02:05 PM
rstephenw
06-07-2004 04:52 PM
Quick Reply: F-250 won't run. Help!
