HELP!! Truck won't start
Old Jun 6, 2004 | 10:56 AM
rstephenw's Avatar
rstephenw
Exclamation HELP!! Truck won't start
I tried to start my 04/04 Lariat PSD this morning and no go. Temp about 70 F, moderate humidity. She cranks and cranks and occassionally "bumps", but won't start.
I drained the HFCM yesterday afternoon and ran it for a couple of minutes afterwards with no problems. Now....kaput.
The oil level is OK. Any ideas?
Old Jun 6, 2004 | 10:57 AM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
...air in the lines??? someone jump in and help me here im not much on fuel systems....
Old Jun 6, 2004 | 11:03 AM
jbullfrog's Avatar
jbullfrog
Call Ford Roadside Assistance. That's what it's there for.
Old Jun 6, 2004 | 11:04 AM
rstephenw's Avatar
rstephenw
Red face
Thanks!!! I hadn't thought of that!
Old Jun 6, 2004 | 11:15 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Sad you need to, however.............the only thing you can do.
It is not major..........we all hope.
Old Jun 6, 2004 | 05:53 PM
blackhat620's Avatar
blackhat620
rstephenw,
If the fan relay on the radiator fan goes bad or the wire comes disconnected vehicle will not start. IMHO i would check the connection.
Hope this helps
Old Jun 6, 2004 | 06:28 PM
swunderle's Avatar
swunderle
fan relay
I'm not to sure abnout the fan relay thing, I have seen many trucks run with the relay disconnected..
Old Jun 6, 2004 | 08:53 PM
International Tech's Avatar
International Tech
could be the fuel pump. crack the lines open and spin her over and see if fuel is coming out. The lines you wanna break loose are at each head (banjo type) but i dunno if you can get to them in the Ford.
Old Jun 7, 2004 | 02:16 AM
blackhat620
rstephew,
Here is a link to causes of a no start situation with the 6.0 PSD.
http://flatratetech.com/6literpowers...ms.htm#nostart
Hope this helps
Old Jun 7, 2004 | 10:00 AM
rstephenw's Avatar
rstephenw
Thanks Blackhat. She's in at the dealer now, so it will be interesting to see what the diagnosis is.
Old Jun 7, 2004 | 10:14 AM
IB Tim's Avatar
IB Tim
When it gets out...tell us what it was
Old Jun 7, 2004 | 10:16 AM
rstephenw's Avatar
rstephenw
Absolutely!! I'll post it in the Problem/Mileage thread.
This site is incredible and the more info we share, the better it will get.
Old Jun 7, 2004 | 04:16 PM
rstephenw's Avatar
rstephenw
The problem turned out to be a chafed wire from the FICM. This kind of problem is really stupid. Because Ford or International did not spend 10 cents for a wire guide, they had to pay $205 in warranty work.
OTOH, I just found out that my diesel technician is the publisher of www.6literpowerstroke.com. 8-))
Old Jun 7, 2004 | 04:26 PM
International Tech
let me guess, at the back by the turbo charger?
Old Jun 7, 2004 | 04:29 PM
rstephenw's Avatar
rstephenw
Yeppers. That's where he described it as being.
