Exhaust
Old Sep 21, 2012 | 12:08 AM
Raleigh234's Avatar
Raleigh234
Exhaust
first off, quick backdrop... The previous owner only used the truck to move the pontoon boat from their house (across the street from the lake) to the lake. so the rear end would get wet, sit, get wet, sit, and so on. a lot of stuff in the rear has rust from the water, including the stock exhaust system. thus, i have a few questions....
advantages/disadvantages to straight tubing it?
if i chose to go with an aftermarket system, would Thrush be a good choice?
Old Sep 21, 2012 | 03:26 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Straight piping it would let the motor breathe better, and when combined with a 3 inch downpipe, youll even feel a power increase. Many go with 4 inch, as well as 5 inch exhausts. As far as brands go, theyre all really the same in my opinion. Find the cheapest stainless kit you can and go with it. You can either buy a kit that goes up and over the axle like the stock one, or run it out just infront of the rear tire.
Old Sep 21, 2012 | 08:22 AM
DIYMechanic's Avatar
DIYMechanic
Advantages:
Relatively cheap
You can hear the turbo singing away at the top of its lungs
Low back pressure
Disadvantages:
Noisy when you get on it
Low Back pressure
I swear it doesn't make any sense but I have had about 4 different exhaust configurations on my truck since I bought it and it runs the best with the 3" DP, no CAT, and the balance of the stock exhaust. I felt a seat of the pants increase in power when I put the stock pipe and muffler back on. It doesn't make a lick of sense, but I swear it is the case.
Here is a thread with some videos of a bunch of different options for you to check out.
https://www.ford-trucks.com/forums/1...eo-thread.html
BLUEMAX65
29
Sep 2, 2017 07:57 AM
David Unruh
Aug 16, 2017 10:00 PM
Krisx125
Dec 8, 2009 10:42 PM
afonda
Dec 26, 2008 01:11 AM
RickDill1
30
Dec 21, 2003 08:24 AM
