HPOP replacement
Old Sep 21, 2012 | 12:40 PM
cheezit's Avatar
cheezit
ipr valve, or stc fitting may be suspect over a pump.
Old Sep 26, 2012 | 09:17 AM
co_alpine's Avatar
co_alpine
I ended up going right back out of town so I have yet to pick the Ex up, I am trying to get back tonight so I can get it and start this weekend on it before it gets too cold out.
thanks for the tips so far, I am making a list of parts to look at and read up on the air test. I got the can tool on order and I think it showed up at the house so I should be good there for this and future issues.
will get back soon on it,
thanks again!!!
Old Oct 8, 2012 | 03:57 PM
co_alpine's Avatar
co_alpine
well, I got into it and found it was a lot worse. the regulator was packed full of little parts that stared the system of oil. got a shop to help and tracing it back all the way it was the plastic stem from the oil filter that had a crack and was at some point cut up to were it was breaking apart. this messed up the oil cooler as well.
so, let's just say I have a lot more upgrades checked off the list earlier than planned.
Old Oct 8, 2012 | 05:35 PM
cheezit's Avatar
cheezit
cracked or melted?
Old Oct 8, 2012 | 07:44 PM
co_alpine's Avatar
co_alpine
Originally Posted by cheezit
cracked or melted?
cracked with missing chunks. while I can't prove it I think I know how/when that started. when I bought the truck used I went right away to do a oil change on it so I knew for sure it was using the right filter and was good to go. I could not get the filter top off as it was cross threaded and the top was all worn off. I tried a few oil can wrenches and could not get it and was worried about putting too much pressure on it as I did not know what was under it. so I took it to a shop to have done. I saw them whacking at it and they broke it off. I am sure either before that (it was used) or at that time the stem was broken and over time it had parts break off and get into the system.
Old Oct 8, 2012 | 07:53 PM
daddykitty's Avatar
daddykitty
i would stomp someones head in if i saw them whacking on my vehicle
Jnas860
Jul 30, 2013 02:54 PM
Chris_in_Texas
Texas Chapter
Nov 14, 2011 05:42 PM
locomike
Oct 24, 2009 11:59 AM
raharms
General Automotive Discussion
Apr 12, 2005 10:39 AM
TrueBlu
Feb 21, 2005 07:33 AM
