HPOP replacement
Old Sep 20, 2012 | 08:25 PM
co_alpine's Avatar
co_alpine
HPOP replacement
so my 05 Excursion is in the shop and was told I need to replace the HPOP as the pressure is under 85PSI. I got a quote of a bit more than 2200 so I looked it up and found all the parts (rebuilt pump and replay kit) for under 650. Is this a really hard one to do? looking at a video it looks like it can be done in the garage in a day or less and not too bad, or is it more of an issue than I can see? is 2200 a good quote on this or should i be paying a lot less for that? <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
also, I just did an oil change 1,500 miles ago, am I going to need to change after this or no? anything else I should know? <o></o>
huge thanks for any advice on this. <o></o>
Old Sep 20, 2012 | 08:45 PM
BLADE35's Avatar
BLADE35
why symtoms did you have
Yes you can change the HPOP
IIRC the 05 X might have the newer HPOP if it does the New HPOP are the good ones not many failures
Have you tried to unplug ICP Sensor and try to start it???
Old Sep 20, 2012 | 08:48 PM
co_alpine's Avatar
co_alpine
I have not done anything to it. it died next to a shop and they pulled me in and did the review on it. i am picking it up tomorrow (been out of town) so I can try that out. they said it was getting 12PSI and found an issue with the orings in the oil rail. i let them fix that as it was $600 and time was short. after that fix it got up to 85 and that is when they said the pump is out.
Old Sep 20, 2012 | 08:51 PM
Fal-308-Win's Avatar
Fal-308-Win
----- Do it in the garage in a DAY or LESS -----? Dang, I wish I knew that before I spent THREE DAYS laying on top of my motor ! Are yo sure you need a new pump ? Can you post numbers from your scangage 2 ? What are your symptoms?
Old Sep 20, 2012 | 08:52 PM
Fal-308-Win
$ang Benny you are typing FASTER
Old Sep 20, 2012 | 09:05 PM
co_alpine's Avatar
co_alpine
back story :
was driving home and it died while taking a turn, cranks fine but no start. I died right by a shop and fire station, the fireman I was talking to said his brother works at the shop and they are good and honest. I said to myself, if you can't trust a fireman why bother, right? so they pulled the truck in and spent time tracking it down. they found the o-rings on the rail were damaged and leaking so they fixed that part. this took it from an oil pressure reading of 12 to 85. I was told that with the issues it could have just died to, so they recommended changing out the pump and the IPR at the same time. they said it could just be the IPR but while it was all opened up should do both.
is there a good way to test the IPR so I don't have to do them both? Looking at the video it would be a LOT easier to just change the IPR out if that is all I need. I don't have a lot of testing gear yet, or the truck at the house, so I can't answer a lot of questions yet. I fly home tomorrow and will be picking up the truck and pulling it home to work on.
Old Sep 20, 2012 | 09:45 PM
Fal-308-Win
Most of us use the ScanGauge 2 , available at autozone for $170.00. It's like hooking your truck up to an EGR' machine at the hospital. It'll trouble shoot the whole motor and the guys here can lead you to the bad components so your not throwing money away. Your problem might be the STC'( slip to connect ) Fitting that attaches to the HPOP' $ 65.00. You need to do an air test on your system to find the leak. All these things are easy to do but first you need to get and set up the scangague2
Old Sep 20, 2012 | 09:50 PM
BLADE35's Avatar
BLADE35
problem is the shops just changing parts and not doing an Air test
I dont buy multiple parts failure at the same time
Plan on a Good Weekend to do it your first time
unplug ICP and try to start
Need to verify you have the right oil filter and Cap
Old Sep 20, 2012 | 09:52 PM
co_alpine's Avatar
co_alpine
so this? ScanGaugeII : Linear Logic - Home of the ScanGauge
one thing i am all for is investing in tools to do the jobs right, so I can pick that up for testing. I have a bully dog triple dog 3 that I got for the truck when I bought it. I use it for monitoring and I run it in the tow/economy state. that will give of error codes too if that is all i need?
Old Sep 20, 2012 | 10:24 PM
Fal-308-Win
Cool
OH OH you ain't gonna believe what you hear next
Old Sep 20, 2012 | 10:26 PM
Fal-308-Win
Cool
Yes that'S the one
Old Sep 20, 2012 | 10:48 PM
Fal-308-Win
You need to read codes too. The SG2 will do that and give live time data from the different systems on the motor
Old Sep 21, 2012 | 08:49 AM
mustang_309's Avatar
mustang_309
There are some other maintenance issuses you can address while you have things taken apart, like the oil cooler and the screen that is under the oil cooler. Also make sure that the only filters you are using are motorcraft and that it has an OEM oil filter cap. For the oil and fuel filters you can use motorcraft or racor (racor makes these filters for motorcraft and are a fair amount cheaper). It would also be a good time to clean up the turbo.
Old Sep 21, 2012 | 09:14 AM
npccpartsman's Avatar
npccpartsman
The other thing I haven't seen mentioned in my quick scan is the STC fitting on the HPOP that has a high failure rate if it hasn't been upgraded.
On Edit: I see where Fal-308-Win mentioned that to you previously.
Old Sep 21, 2012 | 11:13 AM
Fal-308-Win
Alpine read jack Britt's post " Good News " ( posted today ) . This is what the Guy's are trying t do for you !
