2003 6.0 No Start
I have a 2003 6.0 No Start rough when started and stalls. Tuck inside a garage.
(Using a Scan GaugeII)
The truck ICP is between 145 to 390, and when it wants to start around 480 and will not stay running at all.
No Codes
We changed out the following,
1. HPO Pump.
2. ICP Sensor.
3. ICP Plug wire.
4. IPR.
6. Fuel Filters, (Both)
7. Oil Filter.
8. Injector O rings.
9. Manifold Gaskets,
10. Most O-Rings.
12. EGR Delete kit, (While every thing was apart.)
13. Batteries Fully Charged
14. FICM (Checked Out)
Still same situation before all items was done,
No Start, It was running very rough for less than one minute.
Is there any items we missed were the high pressure pump is located,
Any info sugestion would be much appreciatied.
Thank you
JNas
Oh that filter housing should fill fast
If it don't there is a pressure regulator by the crankshaft pulley you could pull and inspect and clean
If that don't get it then inspect LPOP Gears
THERE is a LPO pressure test port IIRC You need around 70psi LPO
HOPE THIS engine isn't coming out looks like you put a lot into it already
Lifter is a BAD Word f or a 6.0L
There a pic of it in the Tech Folder under 6.0L Bible
2. I did not do any air test,.
3. Its a new pump installed, NEW form local ford dealer.
The oil filter was removed and, crank the truck and the area were the oil filter was filled up in 14 seconds to top, and it drained very quickly.
The filter housing filled up with in 14 seconds to top, and drained very quickly
However there is a Drain in the Bottom of the oil filter housing that NEEDS To be held Closed during the Test
shure would feel better about it if the oil filter housing filled in Half that time so check it again holding drain closed
Also here is a Picture of the LPO Regulator
And here is another Pic of the LPO Test Port
its pic#43
The test port towards front truck part of the Oil Filter Adapter
its pic#43
It was around 13, to 14 seconds and filled the housing completely up, and drained very quickly.
Do I have a oped float in the filter housing, not building pressure,
The oil should not drain back from the anti-drainback,
Would this cause hard to no start.
(The oil should remain in the oil filter housing the way I am reading, and it drains right back quickly, and when I start it it fill up the housing with ou holding drain plug in.)
check valve that keeps oil in the oil
Under normal conditions the Oil Filter HOLDS the Drain Down
this is why OEM CAP and Filter is a Must
when you do an oil change the Cap is unscrewed and the filter comes up allowing the Housing to Drain
14 Seconds to FILL the Housing is FlatA$$ Terible
this LPO System should be flowing around 19Gallons per Minute
It Must Fill faster than that and Looks like your Problem at this time
Only other thing is to test LPO Pressure at the Test Port in the Oil Cooler Housing and IIRC should be around 70psi for LPO
I will test the LPO pressure on Monday, truck is at my shop,
appreciate the time and feed back,
