Torque Spec's
Old Sep 20, 2012 | 01:25 PM
2002 Excursion's Avatar
2002 Excursion
Smile Torque Spec's
Changing trans fluid & filter, Tranfers case fluid, front & rear difffentials fluids. Need to know bolt torque spec's. Can anyone help me?
2002 Excursion V-10
Old Sep 20, 2012 | 02:29 PM
EXv10's Avatar
EXv10
2002 Excursion V-10
Who needs 'em.......not me. That stuff doesn't need to be tight, take it easy.
Old Sep 20, 2012 | 03:27 PM
housedad's Avatar
housedad
rear axle oil filler plug - 15-30 lb-ft
front axle oil filler plug - 20 lb-ft
Trans pan bolts - 11 lb-ft (4R100 trans)
Source - Ford 2005 Truck Specifications Book
Old Sep 20, 2012 | 03:38 PM
2002 Excursion
Thanks Bion (AKA:Zombie Crusher)
I'm taking both differential covers off to do a thorough cleaning. You wouldn't have the bolts torque spec's for front & back would you?
Thanks a heap!!!
2002 Excursion
Old Sep 20, 2012 | 04:34 PM
EXv10's Avatar
EXv10
Thanks a heap!!!
2002 Excursion
Just go easy, it's not a problem.
Old Sep 20, 2012 | 04:44 PM
2002 Excursion
Thanks Brent. I'll keep that in mind.
Old Sep 20, 2012 | 05:38 PM
Tom's Avatar
Tom
If that were the case they wouldn't bother with torque specs. But they do:
Rear diff cover: 28-38 ft-lbs
Front diff cover: 35 ft-lbs
Old Sep 20, 2012 | 05:41 PM
EXv10's Avatar
EXv10
99% of the mechanics would never torque those........guaranteed.
You can find specs for almost anything.
Old Sep 20, 2012 | 05:42 PM
Tom's Avatar
Tom
Completely believe it. Which is why I do my own work!
Old Sep 20, 2012 | 07:51 PM
EXv10's Avatar
EXv10
I bet you torque your catchup bottle
Old Sep 20, 2012 | 07:54 PM
Tom's Avatar
Tom
I find no torque value for a catchup bottle. I do see one for a ketchup bottle though. I wonder if this is one of those torque to yield thingies....
Old Sep 20, 2012 | 09:12 PM
EXv10's Avatar
EXv10
You found a torque value for a ketchup bottle? Do tell, I need it.
Old Sep 20, 2012 | 09:30 PM
housedad's Avatar
housedad
Torque control for bottle caps is a big business.
Take this company for instance:
Precision Torque Control, Inc. - Capping Headsets
And here's a chart!!
SKS Bottle - Torque Guide
Old Sep 20, 2012 | 10:54 PM
Stewart_H's Avatar
Stewart_H
I wonder if it's the same value as for a catsup bottle cap.
Hmmmmmmm...
Stewart
Old Sep 20, 2012 | 11:33 PM
EXv10's Avatar
EXv10
Hmmmmmmm...
Stewart
Actually my Heinz bottle says ketchup but I thought it was catsup but ended up with a compromise of catchup.
