Cold air intake
Old Sep 19, 2012 | 08:53 PM
FordYoungGun35's Avatar
FordYoungGun35
Cold air intake
Got a 96 5.0 f150 and just put a cold air intake on and could already tell a difference but I was sent two cones and as of now I have one
Hooked up.. My question is if I hook up both cones one on each side of the y piece of the intake will I gain or lose anything
Old Sep 20, 2012 | 12:30 AM
Evan_P's Avatar
Evan_P
To be honest, you never gained anything by putting in that ""cold" air intake you bought. The truck already had a true cold air intake from the factory. That's what that pipe running from the bottom of the filter box to the top of the radiator does. By having those cones with no box around them in the engine bay, you actually made it WORSE due to it now just sucking in hot engine bay air... If you really want a cold air intake, return the one you bought, get an air box from a 4.9 or 7.5 truck and put that in. It pulls cold air strait in from the grille...
Old Sep 20, 2012 | 12:37 AM
khadma's Avatar
khadma
Carpenter Local 745
I got an extra intake from a 4.9, just waiting for someone that needs it
Old Sep 20, 2012 | 01:14 AM
FordYoungGun35
Even if I have a functional hood scoop
Old Sep 20, 2012 | 09:50 AM
rla2005's Avatar
rla2005
Not unless those little filters are somehow sealed off from the engine compartment so they can draw in cold fresh air from the hood scoop. Otherwise the engine is heating up the air faster than your hood scoop can shove in or draw out air, depends on which way it faces and where it is placed.
Your truck is a 1996 F150 w/5.0L engine, you should have had a MAF meter attached to the side of the factory airbox. How in the world are you using these cone filters with the MAF meter? Pics would be nice....
Old Sep 20, 2012 | 10:00 AM
FordYoungGun35
The metal section of the air tube that the mass air is mounted on is still hooked up.. The sensor is on the inside of the tube and it's still
Hooked up as a part of the intake.. So should I hook the other one up or not?
Old Sep 20, 2012 | 10:03 AM
FordYoungGun35
Like would it hurt? Anything? Keep in mind the motor will
Be getting pulled and rebuilt sometime before next sunmer
Old Sep 20, 2012 | 11:15 AM
rla2005's Avatar
rla2005
You might actually lose some MPGs with this setup, but if it fits your needs go for it.
Old Sep 20, 2012 | 01:19 PM
UNTAMND's Avatar
UNTAMND
I'm curious as to how all this is mounted also.
Can you post pics
Old Sep 20, 2012 | 01:42 PM
rangergirl94's Avatar
rangergirl94
I had a 302 with a cold air intake and exhaust it got better mpg and more power than my dads 96 302? But idk much bout them im an i6 guy
460GasMeister
May 6, 2014 10:43 PM
colorado99_f250
39
Feb 7, 2010 07:42 PM
2pazr
1983 - 2012 Ranger & B-Series
Feb 15, 2009 11:15 PM
Samsonitesamsonite
Sep 10, 2004 06:34 AM
