Loose steering
Old Sep 19, 2012 | 08:45 PM
passengerdoorsmud's Avatar
passengerdoorsmud
Loose steering
Just bought another truck, 83 f250. Doin the once over and it has loose steering. Any idea what the fix is?
Old Sep 19, 2012 | 09:33 PM
Gary Lewis's Avatar
Gary Lewis
We can't tell you what is worn since there are many, many possible problems. However, I've seen more worn out sector boxes than I have worn tie-rod ends or ball joints.
Have someone turn the wheel just enough to take the play out of the steering while you go look. Start with the steering column under the hood and check to make sure the shaft into the sector box is turning the same amount as the shaft coming out of the cab. You may have to pull the plastic cover over the input to the sector box to be able to tell.
Then, do the same with the sector box - look to see if the output is moving the same amount as the input. My guess is that it won't be and that your box is worn. If so, it is replacement time as the adjustment on top will only take the feel out of the steering if you take out any slack.
But, go on and watch the rest of the linkage to look for movement on one side and none, or reduced movement, on the other. That way you will find the wear points.
Old Sep 20, 2012 | 02:38 AM
joshofalltrades's Avatar
joshofalltrades
tie rods, ball joints, axle pivot bushings, they're all normal wear items capable of causing your symptoms. start with the steering box as mentioned above, and follow it down as needed.
one thing i learned last month is that to check the axle pivot bushings, you'll need to raise the truck by its frame, so there's no weight on the suspension. mine were destroyed.
on an F150 i used to have, the frame was shattered around the steering box, causing the whole frame rail to move around, and obviously causing one helluva steering nightmare. it was damage from a previous collision. take a look around at everything while your buddy is working the steering wheel
as with any problem, diagnose until you're sure what it needs, then start buying parts for it
Old Sep 20, 2012 | 05:42 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Frames are known to flex and break at the steering box.
It is not uncommon, especially with lifted trucks that have tires wider than stock.
With an 8" lift I would also take a very close look at the drop pitman arm.
Rag Joint, Ball joints, and tie rod ends take a lot of abuse in a truck like that, moreso when driven on pavement.
IrishMike
Nov 29, 2016 05:23 PM
publiuss
Jul 12, 2012 12:23 PM
Freightrain
Aug 10, 2011 10:53 AM
titanminator
Nov 19, 2010 03:47 AM
78bigunns
Oct 3, 2006 09:05 AM
