Steering play
Old Nov 18, 2010 | 02:52 PM
titanminator's Avatar
titanminator
Steering play
Im at a lost here. I have an 89 F250 2wd with lots o steering play. I first replaced the center drag link which gave it a sligth improvement. Next the steering box replaced, improved a lot. Now, still have play and steering wander in the freeway. What else can it be?
Old Nov 18, 2010 | 03:25 PM
rupejosh's Avatar
rupejosh
tie rod ends ball joints pitman arm......
Old Nov 18, 2010 | 04:10 PM
SnuffthePunkz's Avatar
SnuffthePunkz
lol. rupejosh, basically everything I need to replace in my truck...
I'll post a video later, it's kinda funny the play I have in my truck, makes the gf a little nervous.
Old Nov 18, 2010 | 04:57 PM
mikecwik's Avatar
mikecwik
did you check where the steering column joins the steering box? rag joint i think its called. if thats ok you might try to adjust the gearbox mesh. someone else can tell you how to do that or you can search it. you just might need a new box.
Old Nov 18, 2010 | 05:05 PM
swooshcmk's Avatar
swooshcmk
I also agree with checking the rubber coupling from the steering joint to the steering box. Mine's got a fair amount of play in it and is on the fix-it list. Also check where the steering shaft exits the steering column under the hood. I've seen it where the shaft rusted tight and no longer telescoped to give under body flex. It basically just hammered the snot out of the lower bearing on the steering column and let the shaft wobble around.
If those check out I'd recommend taking it in for an alignment. Improper steering geometry setup can cause a truck to wander around.
Old Nov 18, 2010 | 06:27 PM
Scratcher's Avatar
Scratcher
My moneys on the rag joint. I had the same issue and swapped it out for a U joint. Free play is gone!
Old Nov 18, 2010 | 07:41 PM
swooshcmk's Avatar
swooshcmk
u-joint? Info on what part you used and where you got it?
Old Nov 18, 2010 | 08:12 PM
Scratcher's Avatar
Scratcher
Borgeson Universal Company :: Vehicle Based Search
Old Nov 18, 2010 | 08:41 PM
swooshcmk's Avatar
swooshcmk
Nice, but yowza that's pricey. I'll stick to my 10.00 rubber donut!
Old Nov 18, 2010 | 08:58 PM
Scratcher's Avatar
Scratcher
Yep its pricey................ But my steering is now responsive and I'm not constantly fighting it.
Old Nov 19, 2010 | 12:08 AM
oreocreaming's Avatar
oreocreaming
had the same issue with mine. rebuilt the box and it was good as new!
Old Nov 19, 2010 | 03:47 AM
tjc transport's Avatar
tjc transport
i ain't rite
another thing to look at is where the upper and power column meet. there is a teflon bushing in there held in by a spring steel clip. if the clip breaks the bushing falls out, and you have instant 1/4 turn play in the steering.
A/Ox4
Apr 3, 2013 10:29 PM
mykdee
Dec 23, 2011 05:29 AM
fzeed
21
Jan 29, 2009 10:14 AM
1984 f-250
May 26, 2006 09:33 AM
