Sloppy steering
Old Jul 11, 2012 | 10:40 PM
publiuss's Avatar
publiuss
Sloppy steering
Just bought an '82 F150 4wd. There is slop in the steering, Is there any way to tighten this up?
Old Jul 11, 2012 | 10:51 PM
85e150's Avatar
85e150
Ford used some joints in the front ends of these things that went to pot pretty early. All those should be gone, but you still have to check every joint and connection to start with. Have someone turn the wheel back and forth, and starting at the steering shaft connector (rag joint, if so equipped, some are slightly different), look at every connection all the way out to the tie rod ends and the axle pivots themselves.
If your box is worn out, time to replace. I've read a couple cautions here about trying to tighten the boxes up. Not sure what the exact problem is, but the posters were adamant about not doing that.
Old Jul 11, 2012 | 11:35 PM
publiuss's Avatar
publiuss
Thanks, I was guessing worn ball joints or something like that. Glad you mentioned the box though. Hope that isn't it.
Old Jul 12, 2012 | 04:34 AM
Ken Blythen's Avatar
Ken Blythen
FWIW, I've actually had good success adjusting the slack out of the steering box.
But, eventually there's a point where further adjustment is counter-productive.
The Haynes manual gives the proper procedure.
Old Jul 12, 2012 | 08:33 AM
Galendor's Avatar
Galendor
Add a 6" lift to the truck and 35" tires. That'll tighten up the steering for you. Improve gas mileage too.
Old Jul 12, 2012 | 12:23 PM
publiuss's Avatar
publiuss
Guess you read my other post galendor. Actually, it probably will help b/c I will rob all the steering gear off the donor truck and he has upgraded everything. Maybe
poppajim
Sep 22, 2016 08:02 PM
passengerdoorsmud
Sep 20, 2012 05:42 AM
F-150_XL
May 11, 2005 07:17 PM
Mr. Raney
Aug 26, 2003 11:48 PM
seymour
Jul 3, 2002 03:56 PM
