When is it time to replace the steering box?
I'd like it to go away.
I jacked up the truck's front end one side at a time, grabbed the wheel at 3 and 9 o'clock and gave her some wiggle.
Nothing moved, same as when at 12 and 6 o'clock. The steering parts seems to be OK, I don't know how else to check it.
I open the hood, grab the steering shaft right near where it terminates into the steering box and rotate back and forth.
I can rotate the steering shaft maybe a good 1/2" left to right, poossibly a little less, but much more than I thought I should.
Is it time to replace the box after all the years of 33" tires? Is there any other troubleshooting I can do?
She tracks well down the road for the most part, it just appears that there is play back and forth and you are constantly adjusting while you drive that little bit.
How can you troubleshoot the tierod ends and ball joints to see if they are OK?
She has new shocks and stabilizer. Lots of the front bushing were replaced by the P.O. if it helps.
Thanks for any input or advise,
Blair
Prechecks for your alignment.
Inspect the pivot point on the Independent front suspension ( IFS ) for play or worn parts.
Inspect the brackets and bolts above the pivot point on the Independent front suspension ( IFS ) for play or worn parts.
Inspect for worn parts or play, any of the following:
Inspect the tie rod ends.
Check radius arm bushings for wear or crack.
Check gear coupling assembly (aka rag joint) on the steering column rod for play.
Check the shaft and joint assembly on the steering column rod for play.
Check for play the drag link.
Inspect the front wheel. (the front wheel bearings for play)
Inspect the ball joint for wear.
Let us know what you found?
-Buck-
If swapping new steering gear box,
Tools needed: tie rod end remover, pitman arm remover, and standard wrenches and socket.
First loosen the big nut on the lower sector shaft below the pitman arm. I think it's 1 1/4 inch or 1 5/16" or can use a very big crescent wrench. Give the wrench a whack with a hammer to break the nut loose. Then loosen the rag joint bolts at the steering shaft at the steering gear box (might consider replacing the flexible couping, aka rag joint). Using a drain pan, loosen the power steering lines from steering gear box, drain power steering fluid in drain pan. The loosen the three bolts on frame holding the steering gear box, while supporting the weight of box when removing the last bolts.
I like using Type F transmission fluid on the flushing and bleeding process.
Might need to call around and check who carries Type F.
https://www.ford-trucks.com/forums/s...796&postcount=2
https://www.ford-trucks.com/forums/s...52&postcount=10
https://www.ford-trucks.com/user_gal...d=94741&width=0
add-a-filter https://www.ford-trucks.com/forums/s...458&postcount=3
-Buck-
I ended up getting her in the air and on jackstands and ended up having to bail for family activities.
Hope to get to her one night after the kids practice this week.
One thing to mention after reading your response, the play is right at the box, and it leaks pretty good.
I'm going to check everything, but I think that in the end I'm going to find out my problem is a worn out steering box.
My seals on the joints appear to be in good shape and have been well greased for their lives. Have to check for some play in the balljoints and tieords though for good measure.
Thanks again for the help,
Blair
Tie rod end remover http://www.toolking.com/productinfo....productid=2212
pit man arm remover http://www.toolking.com/productinfo....productid=1247
