got some weird things happinging
Old Sep 19, 2012 | 06:20 PM
Mikey Oldaker's Avatar
Mikey Oldaker
so the other day my injectors were leaking around the return lines and i decided to pull them and put my remans in there because they had new o-rings on them then the stupid thing didnt want to start every time becuase of this. so i ended up pulling my remans out and putting the others back in it and at this point it started running funny. there was only about a 2-300 psi difference in the pop pressure so i figured tht it wouldnt make much of a difference but when i put them back in it started acting like its missing and its not wanting to idol right its really shaky like bad horrifically shaky and every time i give it a litle bit of throttle it sits at the rpm that it gets up to for a min then comes back down and trys to die. all the while it sounds like its missing really bad. when you start it up it starts just fine but doesnt want to run right anyone have any ideas as to what its doing or why its doing it i just bought this motor and guy said it only has 150 k on it i have ended up putting my remans back in it and the original ip for guy had said it was rebuilt before his brother wrapped it around a tree but this is my get around truck and i need to figure out what its dam deal is and why its being weird its a 83 style motor 6.9 any ideas would be greatly appreciated
Old Sep 23, 2012 | 09:46 PM
rupejosh's Avatar
rupejosh
did you make sure you got the copper washers out?
jdneal88
Aug 6, 2016 09:52 AM
Jerry Chaney
May 19, 2014 07:32 AM
matt71
Feb 12, 2009 02:18 PM
bigbadwolfe
Jun 7, 2007 07:08 AM
fetchitupdawg
Feb 13, 2005 10:30 AM
