Odmeter
Old Sep 19, 2012 | 04:56 PM
midsouth's Avatar
midsouth
Odmeter
On my 83 f150, the odometer stopped today. Is there a simple trick to getting it rolling again and do I need to get someone qualified to repair it?
Old Sep 19, 2012 | 07:38 PM
1983F1503004x4's Avatar
1983F1503004x4
There's two gears on your speedometer. One in the transmission or transfer case (drive gear) and one on the end of the cable (driven gear).
Best thing to do is pull the cable from underneath and inspect the gears to see what kind of condition they're in. I'm willing to bet that one of them has sheared off.
It also wouldn't be a bad idea to change your fluids in either the transmission or t-fer case that the cable plugs in to so that you're sure that no chunks of that gear may be floating around in there.
Old Sep 19, 2012 | 07:47 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
If the speedometer still works, but the odometer quit, or the speedometer quit but the odometer still keeps track of mileage, then you need a new speedometer head.
If both quit working, check like 1983F-1503004x4 describes...
Old Sep 19, 2012 | 07:53 PM
1983F1503004x4
Yes! What he said!
I took Odometer as Speedometer as well.
Let us know if you manage to fix it.
Old Sep 20, 2012 | 08:59 AM
1986F150six's Avatar
1986F150six
The original poster did not mention whether or not his truck has a resettable trip odometer, but if so equipped, it is very important to reset the trip meter only when the vehicle is not moving.
Resetting the trip meter while moving will most likely damage the gears inside the speedometer head and the trip meter will no longer work. Sometimes, though, the odometer and speedometer will continue to function normally.
dixiehornford
Electrical Systems/Wiring
Sep 29, 2017 06:15 PM
hugger94
Jan 6, 2010 03:38 PM
hittman1422
Apr 3, 2009 05:34 PM
ubereal2
Aug 15, 2007 09:16 AM
banditjax
Jul 22, 2003 04:15 PM
