300 6CYL
Old Sep 19, 2012 | 04:11 PM
DOC G's Avatar
DOC G
300 6CYL
I need to replace my 1981 F100 300 6 and have a 1985 300 long block available to me. Will this engine work. Thanx for any help.
Old Sep 19, 2012 | 04:29 PM
Labhound's Avatar
Labhound
Yes it will.
Old Sep 19, 2012 | 07:17 PM
1983F1503004x4's Avatar
1983F1503004x4
Make sure you keep the ignition components from the 81, as the 85 is a computer controlled model with a feedback carburetor. The 81 is a Duraspark II electronic ignition without the computer controlled carb.
Also, make sure you use the 81's carburetor and distributor.
Old Sep 19, 2012 | 08:05 PM
DOC G's Avatar
DOC G
Thanx old motor has a holley 4bbl on an offy and headers. no
No emission. I will just move everything over to new block.
Old Sep 19, 2012 | 09:33 PM
1983F1503004x4
Are you running a fabbed up water-heating plate to bolt to the bottom of the intake?
The intake needs heat so the fuel doesn't puddle and cause bogging/inconsistent burning.
You'll notice better power, smoother running, and better gas mileage if you're running the plate. You also can't completely tune out the bogging from running the intake without heat.
DeathProofDuck
Feb 1, 2015 03:55 PM
bob1987f
13
Jul 29, 2008 11:31 PM
jeff8362000
18
Nov 20, 2007 10:19 AM
4wheeltank
Oct 6, 2005 08:50 AM
Rob
Jan 25, 2000 10:05 PM
