Injector 6 replacement
Old Sep 19, 2012 | 09:16 AM
J24772477's Avatar
J24772477
i have a 06 f250 with a bad injector. Is it worth thee 700 bucks to get it done at the dealer or is it a job you can do at home? The truck only has 44,500...
Old Sep 19, 2012 | 09:34 AM
John Irwin's Avatar
John Irwin
Very possible to do it at home, I did. Here is a good thread from the tech folder telling you what you need for tools, and how to do it.
https://www.ford-trucks.com/forums/5...ml#post4355612
Old Sep 19, 2012 | 03:37 PM
swcollins's Avatar
swcollins
I replaced mind at home, but it did not fix the problem....and a Ford Dealership is who told me that it was bad.....shows P0276 P0278, so now trying to locate electrical problem... out the cost of an injector.
Old Sep 19, 2012 | 03:47 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...and even then it may NOT be the injector.
Who said it was an injector? Do you have a Scan Gauge II yet?( Or equivalent) Every 6.0 driver should have this instrument to help with troubleshooting their engine problems!
It COULD be the FICM low voltage. Or a number of other things.
Old Sep 19, 2012 | 04:53 PM
John Irwin's Avatar
John Irwin
Bud, I was just assuming since he specifically said #6 injector, he knew it was bad. And anybody with that many numbers in their pseudonym must be smart...
Old Sep 19, 2012 | 05:12 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
John, I was looking at the low number of posts he has (5). ***-U-ME nothing!!! LOL
Old Sep 19, 2012 | 09:48 PM
zhilton's Avatar
zhilton
Where in TX are you? There are a couple of PSD savy folks scattered around TX that could give you a hand figuring out if (A) if you have injector problems and (B) give you a hand getting it fixed.
Exactly!
Old Sep 21, 2012 | 11:24 AM
J24772477's Avatar
J24772477
I live here in San Antonio. I really need all the help I can get. I really appreciate it. You guys are awesome. It really helped looking at those links. Truck is running great again....
Old Sep 21, 2012 | 01:22 PM
BLADE35's Avatar
BLADE35
So what was the FIX a New Inject#6?????????????????????
Old Sep 21, 2012 | 01:41 PM
J24772477's Avatar
J24772477
Yes sir it was.... Now it runs like a champ again....
Old Sep 21, 2012 | 01:48 PM
BLADE35's Avatar
BLADE35
thanks for posting the Outcome reps Given
Shure helps others when they search for a Fix
fireman660r
Apr 11, 2013 06:33 PM
cefloyd
May 1, 2012 02:46 PM
SoTxShooter
Nov 15, 2010 06:32 PM
hansont
Aug 16, 2007 12:59 PM
gomfrddy
Nov 9, 2006 03:29 PM
