Locking Hub Questions
Old Sep 19, 2012 | 07:29 AM
hawgystyle's Avatar
hawgystyle
I have a 2002 F-250 and after I rolled over 300K miles one of my hubs finally went out. I wanted to know what spline my axle would be so i can order some new ones and what brand should i get, i was planning on getting warn.
I had one hub break about a month ago and I only had the driver side hub lock. Now im having another problem. I have 4x4 shift on the fly with locking hubs. I noticed that i have vaccum lines going to the hubs. And now the driver side will not lock and no vaccum is going into the lines. i replaced all the vaccum lines to make sure i had no leak but i found the lines conected to this unit (i dont know what it is) (has a wiring harness the plugs into it). I think it might be bad but i dont know what it is. What is that part called. I know it is bad because i found water in the vaccum lines and it went all the way to this component and i dont believe water and electricity mix to good.
Old Sep 19, 2012 | 09:02 AM
Firefighter 1406's Avatar
Firefighter 1406
I think the only difference is the dually front axle and the single rear wheel front axle. If I remember correctly there is only two different part numbers for our trucks. Check out warns website, it should be able to get the number for ya. You will not regret the warns. Have Warn premiums and I love them? I think Clay at riffraff has the best prices I have seen on them.
Old Sep 19, 2012 | 10:13 AM
hawgystyle's Avatar
hawgystyle
Alright, I found the right hub to install and they are ordered. Now just to figure out what this part is that might be causing the rest of my problems
Old Sep 19, 2012 | 10:35 AM
SARDiverDan's Avatar
SARDiverDan
If you go with WARN the vacuum lines will no longer be used anyway as they are fully manually operated hub so you don’t need to fix the other issue
Old Sep 19, 2012 | 11:27 AM
sledhead999's Avatar
sledhead999
Similar question. When I changed out my ball joints, I lost my electronic vacuum 4x4. Which usually goes bad the steering knuckle seal at the back or the yellow o-ring up front or both? I greased both putting them back in, but they must still leak...
Axle Vaccum Seal
O-ring
Old Sep 19, 2012 | 07:34 PM
hawgystyle's Avatar
hawgystyle
So the Stock Manual Hubs require a vacuum to lock in?
Old Sep 19, 2012 | 08:43 PM
sledhead999
If you have the electronic 4x4 shifter instead of the manual lever on the floor, yes. They are manual in one position and auto in the other. If you have the manual lever, hubs are either in or out, no auto position.
Old Sep 20, 2012 | 07:08 AM
hawgystyle's Avatar
hawgystyle
Ok, that makes somewhat sense. So do i need anything else when i get the warn hubs to make them work?
Old Sep 20, 2012 | 07:12 AM
hawgystyle's Avatar
hawgystyle
I was told i need a Warn Spindle Kit if i had auto hubs, but since mine are manual I should not need that kit right?
Mumbly Joe
Sep 9, 2016 02:00 AM
TinyWonder
Mar 1, 2011 10:21 AM
Sakison
Feb 10, 2010 08:11 AM
hdman6
Sep 19, 2008 08:41 PM
