E4od EEC computer
Old Sep 21, 2012 | 11:24 PM
kobaltblue's Avatar
kobaltblue
Originally Posted by onpier5
Link still does not work. Was it taken down?
Try this post
https://www.ford-trucks.com/forums/1...-or-4r100.html
Scroll down to post #6
Old Sep 21, 2012 | 11:26 PM
kobaltblue's Avatar
kobaltblue
That one works just tried it.
Did you check all your grounds too, Motor to chassis,Battery to chassis,Battery to engine,Computer to chassis.
I have six grounds on my engine to chassis,You cant have too many grounds the way these suck up the juice.
Old Sep 21, 2012 | 11:31 PM
onpier5's Avatar
onpier5
Thanks, that worked. I will read thru it.
Old Sep 22, 2012 | 04:29 PM
kobaltblue's Avatar
kobaltblue
You may want to unplug your computer and go pin by pin with a OHMs meter and test they all work and there is no breaks in the wires its not too hard to do probably take a few hours, You just got to narrow it down item by item.
Old Sep 22, 2012 | 04:47 PM
onpier5's Avatar
onpier5
Ok thanks. The truck is at the trans guys shop now. I will post follow up when I get it back. I read thru the zip file. Wow. Awesome info for the future. I read in there that if you plug in a 1995 sol pack that it will ruin the computer. That's what the previous
Trans guy did. But EEC is sending the right signals to solenoid pack like I said in previous post with the way I hooked up light to see solenoid pattern from EEC. Trans guy has a
tran-x to hook up to tranny to shift it with our the EEC. So we will see what happens. I will keep you posted.
Old Sep 24, 2012 | 08:31 PM
onpier5's Avatar
onpier5
Update, got truck back. Trans guy checked everything out. Everything checked out ok, so he replaced the valve bodies with a matched set he had, and threw away the old ones. Now it works great, shifts a little too soon, around 2200rpm, sometimes 1900rpm. I will recheck the tps and dial it in. Thanks for all of the help and recommendations.
Old Sep 27, 2012 | 08:28 PM
onpier5's Avatar
onpier5
Trying to adjust fipl. 1.3volts at idle and 4volts at wot. Can someone tell me at what rpm's the trans should be shifting at? Mine is shifting at around 2200 rpm. Sometimes 1900rpm.
Old Sep 27, 2012 | 10:51 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
thats decent.if you can,try and tweak it closer to 1.2v idle/4.5 wot but your in the ballpark.
Old Sep 27, 2012 | 11:38 PM
onpier5's Avatar
onpier5
Ok. Thanks. I guess I am so used the the trans being screwed up. I was just expecting more of the same. Lol. I will try adjusting it more.
flyboyd8
Apr 18, 2023 06:50 PM
Matt Redelback
31
Jan 15, 2019 04:21 PM
nick2064
Apr 4, 2017 12:31 PM
FghtinIrshNvrDie
48
Jun 14, 2006 11:53 AM
7.3burnoutbuddy
Apr 5, 2006 09:49 PM
