Inner snap ring on warn hubs
Old Jan 2, 2013 | 09:46 PM
gcostermeier's Avatar
gcostermeier
TJ, and cathunt, , I had the same snapring come off on my new Warn hub. I posted on another thread with more details. It happened twice on the same side, and twice i put it back together. Now, i also swapped sides, and also greased the axle shaft up good, and now it is staying put. I do not know exactly went wrong on mine, but so far, so good. Warn gave me a list of things to check, like wheel bearings, driveshaft joints, and needle bearings, but i am pretty sure all this is OK on my truck.
What did you learn about the cause for your problems, or, how did it get solved?
Old Jan 3, 2013 | 10:46 PM
cathunt's Avatar
cathunt
I have put it back together two times on this new hub it has been about a month and all is good i hope. If not i will try to grease my axle shaft like you said maybe there is a bur or something on it. i dont know, if you find out any more info let me know thanks.
Old Jan 4, 2013 | 07:31 PM
gcostermeier
I sent Warn an explanation of what the problem was, and that i swapped/greased the hubs, and now no more problems.....they offered to replace the hub anyway, no more questions asked........
Old Jan 15, 2013 | 08:40 PM
gcostermeier
Well, i have to say i am very impresses with Warn's customer service...2 new hub locks showed up at my door today.
VORTMAX_99
Nov 26, 2016 12:16 PM
wrdabney
Oct 7, 2016 03:29 PM
kidoo
Sep 23, 2011 11:25 AM
Dj300ford
Offroad & 4x4
Feb 4, 2006 04:16 PM
teederj2002
Jul 30, 2004 02:59 PM
