Let's Talk About Radiator Caps!
Old Sep 18, 2012 | 12:43 PM
BeerCan500's Avatar
BeerCan500
Hello All, For our IDI engines...What would be the correct radiator cap...a 7 lb, a 13lb, a 16lb, or ?
Seems to me...the higher the poundage the more pressure our cooling systems have to work at, thereby leading to more leaks if you have some weak spots...such as maybe head gaskets, old radiator, old hoses, weak clamps, etc...
I know the higher the poundage, the higher the temp the coolant has to reach before boiling...Wouldn't it be better to use a lower poundage cap and let the system utilize the overflow tank more as the fan kicks in to cool things back down and suck the coolant back into the radiator...and again...might this alleviate a lot of "where is all my coolant going" and "I can't find any leaks"...
Just thinking this out logically...Maybe I'm totally wrong...so what info or ideas do you guys have?
I am thinking og going to a 7 lb cap...
Old Sep 18, 2012 | 12:50 PM
dsltech83's Avatar
dsltech83
Factory correct is 13 psi, that's whats on my truck. Lowering pressure lowers boiling point and that's not good if you do any towing. You could convert to Evans waterless and run a 0 psi system. Expensive but worth it.
Old Sep 18, 2012 | 02:30 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
the cap that said motorcraft on it when i got my truck said 16lb. the cap that came with my new rad was also 16lb. no issues.
Old Sep 18, 2012 | 02:41 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
both are incorrect though.
13 lb caps for the idi like stated.
id just swap it out if i where you.why risk blowing a head gasket for such a cheap and easy part to replace right? may not have issues...yet.but post back if you blow a gasket in the future,or something else comes up for everyone.people running ELC coolant i doubt are posting about their failed water pumps either.
Old Sep 18, 2012 | 02:50 PM
whiteboyslo's Avatar
whiteboyslo
13psi is factory, per the original cap on my truck I just replaced with a new OEM piece that says the exact same thing.
Running a cap lower than stock would be tempting fate IMHO, unless you're running some kind of coolant that has a much higher boiling point like the Evans.
Here's a spreadsheet that I keep running into every time I research anything coolant-related. I can't validate its accuracy, but it at least gives you a rough idea of the effect your cap pressure and your coolant mixture has on the boiling point:
http://www.heat-transfer-fluid.com/p...ling-point.pdf
FWIW, the Old Wive's tale I always heard about higher pressure caps is that they're hell on older copper/brass radiators but aluminum cores are more stout and can take the pressure.
Mike
Old Sep 18, 2012 | 03:29 PM
Onus's Avatar
Onus
Never heard of water pump failures due to elc.
The radiator cap increases the boiling points. It's like sticking water / antifreeze at a higher elevation. I remember seeing a chart somewhere but, the pressure makes a big difference.
Old Sep 18, 2012 | 03:33 PM
Marianna2003's Avatar
Marianna2003
You need 2 things to prevent cavitation:
1. Proper SCA levels.
2. Proper pressure on the coolant.
Old Sep 18, 2012 | 04:57 PM
whiteboyslo
Lower elevation, actually. The higher the pressure of the system, the higher the temperature you need to hit before it'll boil. This is why water boils at much lower temperatures at high elevations (e.g. Denver) versus at sea level.
Mike
Old Sep 18, 2012 | 06:55 PM
monte97z's Avatar
monte97z
FWIW I have a leaking head gasket I'll eventually replace it but for know it is external leak only and I go through very little water so I live with it. I went to a 7lb cap last month figuring I would slow my leak or stop it cause of the lower pressure. That lasted me about an hour. Truck was empty and I was driving easy she warmed up quicker and got much hotter. I pulled over once I hit 215 and let it idle for a few min while I checked for leaks. Got back in and I was at 220 shut it down replaced the 7lb cap with the 13lb one. For the rest of the day she never broke 190. Learned my lesson quick, book calls for 13 it gets 13. Sorry for the long post hope I can save someone from making my mistake. With out the aftermarket gauge I prob would have finished off my head gasket.
Old Sep 18, 2012 | 06:57 PM
Onus's Avatar
Onus
Mike
ahh. I'm not too up to par with my boiling physics.
Old Sep 18, 2012 | 07:05 PM
joshofalltrades's Avatar
joshofalltrades
marianna beat me to it. pressure is critical to prevent cavitation. there's some uncertainty in this thread if its supposed to be 13 or 16 pounds, but i wouldn't touch anything less. now on a gasser, it doesn't matter much, as cavitation isn't an issue.
Old Sep 18, 2012 | 07:58 PM
whiteboyslo
Still gotta worry about overheating, though......
Mike
Old Sep 18, 2012 | 08:05 PM
joshofalltrades
Mike
you mean for us or for a gasser? on a gasser, IF the temp never reaches its natural boiling point, you'll never be aware of a cap that doesn't seal. its only noticed when you exceed that temp and start steaming out.
Old Sep 18, 2012 | 09:04 PM
whiteboyslo
On any engine. You're absolutely correct, but running a pressurized system raises that boiling point, hence hedging your bet.
In the end, I guess all I'm saying is that I don't think running lower pressure caps is a great idea, especially if all you're trying to accomplish is to mask potential problems that could otherwise be dealt with by proper maintenance.
Mike
Old Sep 18, 2012 | 11:22 PM
'94IDITurbo7.3
1994 Ford F-250 - Radiator / Coolant Recovery Tank Cap | FordParts.com
Korya
Nov 1, 2016 09:22 PM
mdlf350
1983 - 2012 Ranger & B-Series
Mar 17, 2014 05:47 AM
jhines
Aug 18, 2010 08:38 AM
ken1mod
Aerostar
18
Sep 3, 2005 08:29 PM
Burris1974
Sep 24, 2003 08:01 AM
