Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1972 Ignition problems
Old Sep 26, 2012 | 01:37 AM
earl6969's Avatar
earl6969
Thanks, I'll look for those.
Old Oct 7, 2012 | 11:20 AM
earl6969's Avatar
earl6969
Traced the wire and it seemed to be loose. That fixed starting. Now it refuses to take gas on acceleration. IT HAS NEW EVERYTHING fuel and ignition related!!!
Old Oct 18, 2012 | 05:34 PM
earl6969's Avatar
earl6969
I have put a new timing gear and chain set on it now. It still won't take gas on acceleration. It has a new carb. , fuel pump, fuel filter etc. Also all new ignition parts.including distributor and timing gear set. Anybody know the points and spark plug gaps for a 391? Any other ideas?
Old Oct 18, 2012 | 06:59 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is there a vacuum advance? Does it work?
Old Oct 19, 2012 | 10:03 AM
earl6969's Avatar
earl6969
yes. all new distributor with new vacuum advance on it. as far as I can tell advance is working. Pulling vacuum with a handheld unit moves it. How can I tell if it's moving while the truck is running?
Old Oct 21, 2012 | 08:56 AM
deck60's Avatar
deck60
2 things I learned about these distributors the mechanical advance under your point plate will get corroded and not work and the bushing on the rod wears and then your point gap varies
you can put on a duraspark from a 390 and have elec ignition that's what I did
my advance wasn't working the mechanical truck backfired started carb and air cleaner and wires on fire so I changed mine out
parts needed
390 oil-pump drive, oil-pump, duraspark distributor gm hei control module
Old Oct 22, 2012 | 01:36 AM
earl6969's Avatar
earl6969
After all the parts and headaches, I checked the fuel flow which was down to a trickle. The engine literally had less than 10 minutes of run time on the new fuel filter I just installed. After another new filter, it runs good once again.
Lesson learned- just because you just put a filter on doesn't mean it fixed it.
Agnew
Mar 16, 2018 01:34 PM
Binkowski
Jun 30, 2014 03:53 PM
matt0963
1983 - 2012 Ranger & B-Series
Oct 24, 2005 07:12 PM
clutch
Oct 19, 2005 08:21 PM
mmford24
Apr 27, 2004 08:59 AM
