Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1972 Ignition problems
Old Sep 18, 2012 | 02:59 AM
earl6969's Avatar
earl6969
1972 Ford F750 with a 391. It was running smoothly and sputtered to a stop. I replaced all ignition components but it will not even try to crank. It's getting fuel. (New points, condenser, coil, distributor, rotor, plug wires, ignition switch) I set the points to .016 which I am told is about right. I have put it together and taken it apart several times for several days. I have even tried hot wiring it and put 3 different sets of each of the components I have in it and I am completely stumped. The closest I have come to getting anything out of it is blue spark from the coil wire to block a few times. Then later red spark from the coil wire with none coming out of the distributor either of those times.
Old Sep 18, 2012 | 08:12 AM
Freightrain's Avatar
Freightrain
There is a problem with your rotors? If it is not transfering to plug wires, it has to stop there. Or your caps are screwed up at the center point terminal(for coil wire) and is not transfering to rotor.
Make sure you can see a wear spot where the center terminal is touching the rotor tab.
I've had same head scratching problem with my '69 f100 a couple times. It would quit, nothing would make it run. Change everything out to known good parts, still nothing. Swap everything back and it would magically run?? Run fine for years, then strangely do it again. I'm still stumped over it(though it's been fine for about 3 yrs now).
Old Sep 18, 2012 | 10:12 AM
merlynr's Avatar
merlynr
Check to make sure you have the coil primary and secondary correct.
Old Sep 18, 2012 | 11:51 PM
smokenchoken's Avatar
smokenchoken
did it possibly jump time? i know it is hard to believe but its always worth double checking.....
Old Sep 19, 2012 | 05:38 AM
earl6969's Avatar
earl6969
thanks for the ideas. I'll try all that.
Old Sep 19, 2012 | 07:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you aren't getting a consistent spark from the coil wire to ground, there's something wrong with either the points, condensor, coil, or voltage getting to these parts.
Before you do anything, with the distributor cap off, crank the engine and check that the points are actually opening and closing. And, of course, that the distributor shaft is turning in the first place
Then, start simple - get a volt meter (better to get a new-fangled digital one from Radio Shack, doesn't need to be more than the basic model), and with the points OPEN and the key on - check the voltage between ground and the (+) side of the coil. Should be somewhere north of 8 volts or thereabouts because of the ballast resistor. If that checks good, continue on...
With the key off, and the points open, check the resistance (ohms) between the (-) side of the coil and ground. It should be infinite after a few seconds (condensor might cause a momentary blip). Turn the engine until the points are closed, recheck - should be 0 or close to it. If good, continue...
I suspect a bad connection somewhere, low voltage, or something else, report back all that you find and we'll continue working on it with you...
When you changed all those parts, was the coil replaced too?
Old Sep 19, 2012 | 11:55 PM
earl6969's Avatar
earl6969
I did put a new coil on it. I put another new condensor on today too: a little more costly one. Getting a definite red spark now, it's just not going out of the distributor. I'll try your check procedure and post results on here. thanks for trying to help.
Old Sep 20, 2012 | 10:10 AM
krewat's Avatar
krewat
Red is not good... should be blue or white, especially from the coil wire.
Old Sep 20, 2012 | 06:07 PM
earl6969's Avatar
earl6969
Before you do anything, with the distributor cap off, crank the engine and check that the points are actually opening and closing. And, of course, that the distributor shaft is turning in the first place GOOD THERE
Then, start simple - get a volt meter (better to get a new-fangled digital one from Radio Shack, doesn't need to be more than the basic model), and with the points OPEN and the key on - check the voltage between ground and the (+) side of the coil. Should be somewhere north of 8 volts or thereabouts because of the ballast resistor. If that checks good, continue on... GOOD THERE
With the key off, and the points open, check the resistance (ohms) between the (-) side of the coil and ground. It should be infinite after a few seconds (condensor might cause a momentary blip). Turn the engine until the points are closed, recheck - should be 0 or close to it. If good, continue... GOOD THERE
still stumped after all that.
Earl
Old Sep 21, 2012 | 07:10 AM
earl6969's Avatar
earl6969
I have a new distributor lead wire ordered. (the one that goes from the points to the (-) on the coil)
Old Sep 21, 2012 | 04:02 PM
merlynr's Avatar
merlynr
I bought a new coil about a month ago and the - and + were reversed on the coil. It was for my 73 Mustang. I reversed the wires and now it's ok. I have the + going to distributor. Made in Mexico.
Old Sep 23, 2012 | 04:58 PM
earl6969's Avatar
earl6969
That figures. I think mine is okay though. It cranked after the new lead wire . It won't take gas on acceleration now.
Old Sep 24, 2012 | 07:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ordered? The autoparts store didn't have one in stock? What's the world coming to? Same puppy: 289/302/330 M/D & H/D/351C/351W/352/360/361/390/391/410/427/428/429/460.
Look inside the dizzy for the short primary wire. The 1957/66 original was bare, 1967 and later version has a black coating on it. The wire could have snapped under the coating.
Old Sep 24, 2012 | 11:51 AM
earl6969's Avatar
earl6969
Do you know where the resistor is? I've looked everywhere. Had to "hot wire" it to get it to crank.
Old Sep 25, 2012 | 01:34 AM
NumberDummy
1972: Two possibles:
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37).
61.49" long / Color coded PINK / 1.30-1.40 ohms resistance / #16 gauge wire.
Or:
D1AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-84-A).
60" long / Color coded RED with GREEN stripes / 1.30-1.40 ohms resistance / #16 gauge wire.
