1973 F100 300 no spark
I've been trying everything to get my new truck running but the ignition system keeps fighting me. It's got a new cap, plugs, rotor, condenser, points, coil and plug wires but I'm still getting no spark. I believe the points are set properly (paperclip-wide gap between contacts when the lobe is out) I don't know what is going on. Since the wiring is a little hacked up I've been running a wire straight from the battery to the +side of the coil. Does it need resistance? Any help is appreciated.
It should start / run without a resistor or resistance wire. I would not run it that way permanently as the coil life may be shortened. When the engine is cranking do you get a spark at the coil wire when it is disconnected from the distributor and held near the block? Be sure the rotor is not installed 180* out of phase.
I've had new condensers that were crap right out of the box. So you may want to try a different one. Also take a multimeter and check the wire the goes from the distributor to the coil for continuity. I've had a couple of those that were bad.
drewduncan15
May 21, 2013 02:25 AM
tn.jed
May 6, 2010 06:29 PM
F250racer
13
Jun 18, 2008 08:09 AM
keyzdiver
Nov 27, 2007 10:41 PM
