Bell Crank Throttle Linkage
Old Sep 17, 2012 | 02:31 PM
grnlzrd's Avatar
grnlzrd
No offense to those of you running a cable, it's just not my cup of tea. So I've been kicking around the idea of a bell crank linkage system.
Here's the basic idea, orange square is the carb, red "L" is the bell crank, black lines are the links, blue circle is bell crank rotation path. I decided to put the fulcrum point where the pedal arm and throttle intersect at a right angle.
I was lucky enough to find this bracket at work.
Marked for trimming.
All trimmed up, and bearing (also from work) pressed in.
I welded a nut into a 3/8 pipe.
All put together.
Heim joints came from ebay. I have a third for the carb end of the link. I plan on putting the threaded rod through the hole in the pedal arm, and securing it with washers and jam nuts with a thick rubber grommet.
Now I need to design a bracket to mount it.
Old Sep 17, 2012 | 04:09 PM
AbandonedBronco's Avatar
AbandonedBronco
What a fascinating idea. How do you intend to connect it to the gas pedal?
Old Sep 19, 2012 | 04:28 PM
TheDudeAbides's Avatar
TheDudeAbides
wow that is way cool! goes to show it's not what you buy, it's what you build! looking forward to more updates on this!
Old Sep 19, 2012 | 04:42 PM
Harte3's Avatar
Harte3
DIY is good stuff!
Old Sep 20, 2012 | 02:55 AM
jem44357's Avatar
jem44357
So I see you do not have an "easy button" in your toy box either. Very creative! A bit along the lines of me stuffing an inline 6 in a FFR Roadster... I like it!
Jim
Old Sep 23, 2012 | 07:51 PM
grnlzrd's Avatar
grnlzrd
Got some work done on the bracket today. May add some gussets between the plate and pipe, and a support down to a lifter cover bolt.
Old Oct 21, 2012 | 06:53 PM
grnlzrd's Avatar
grnlzrd
Made a video of the linkage in action the other day:
<iframe width="420" height="315" src="http://www.youtube.com/embed/9NTw1oVJhNM" frameborder="0" allowfullscreen></iframe>
Old Oct 22, 2012 | 02:28 PM
1986F150six's Avatar
1986F150six
Very nice! The engine sounds great!!
Old Nov 11, 2012 | 11:48 PM
TheDudeAbides
job well done friend. looks sharp and sounds great!
Old Nov 14, 2012 | 07:47 PM
68cabby's Avatar
68cabby
Good grief...that's an awesome idea! I'm still trying to figure out how to convert my old bell crank throttle to an i6...
bluesalomon
Apr 28, 2016 08:34 AM
Jafo56
Sep 24, 2015 07:44 PM
4strats
Jun 30, 2015 06:49 PM
Velocity2
Nov 27, 2014 12:11 AM
teardropty
Aug 1, 2012 07:38 PM
