RR issue
Old Sep 17, 2012 | 10:35 AM
Shattered's Avatar
Shattered
RR issue
Question, when I shut my truck down I can watch my fuel pressure drop rapidly. Is this normal, or am I getting air in somewhere? Also if truck sits for a day or so, it starts then dies, and then it takes a few seconds to fire back up. Is this due to the fuel pressure dropping as soon as I turn the truck off?
Old Sep 17, 2012 | 10:49 AM
timmyboy76's Avatar
timmyboy76
How's your r.r. setup. Do you still use the oem hard fuel lines? If so, ford has a bleedoff checkvalve at the poerts where the hardlines connect to heads. It was needed or else there wud be 75+psi sitting dormant in the fuel rails while trucks off. Can't see that being gud on injectors or orings
Old Sep 17, 2012 | 10:56 AM
Shattered's Avatar
Shattered
No stock hardlines left. but I also had to relocate the fuel pump about mid-ship to get it in-between my filters, I could not use the stock pushlock fittings on the pump and had to go another route. could I be getting air in by the pump.
Old Sep 17, 2012 | 11:04 AM
timmyboy76's Avatar
timmyboy76
No, the stock pump lines were horrible. If replaced with fuel line and hose clamps, I don't think airs introduced there, or anywhere. When my wvo gets low, or when I turn,and pump loses fluid, I se my fuel psi gauge drop to 0. When you turn ur truck off, fluid draws back, from the regulator, back thru the heads, out the fuellines,ba k to down thru filters and pump, ending in the tank....
Old Sep 17, 2012 | 11:11 AM
Shattered's Avatar
Shattered
ok. just really weird, I can't figure out why it will fire immediately then die, then I have to crank on it for 15 or so seconds to get her to fire up. But once she does, runs like a raped ape.
Old Sep 17, 2012 | 11:18 AM
timmyboy76's Avatar
timmyboy76
How did u plumb the r.r?
Old Sep 17, 2012 | 11:21 AM
Shattered's Avatar
Shattered
from tank, I went to water seperator, fuel pump, fuel filter, then to a T-fitting to the rear of the heads, from the front of heads to regulator and from bottom of regulator to return line.
Old Sep 17, 2012 | 11:29 AM
timmyboy76's Avatar
timmyboy76
Sounds gud to me. I think ur getn the bleed back of fuel. Try cycling the key a few times, to prime system, see if that helped.
Old Sep 17, 2012 | 11:35 AM
Shattered's Avatar
Shattered
that does help, but should I have to do it more than twice? my next guess would be new fuel pump, maybe mines getting tired
Old Sep 17, 2012 | 11:41 AM
timmyboy76's Avatar
timmyboy76
Check ur psi setting, se if pump is able to hit it. If so, and have flow thru the eturn line, then id think the pump is gud to run.
Old Sep 17, 2012 | 11:42 AM
joeyd61's Avatar
joeyd61
how rapidly is the drop off?? mine takes appx 15 minutes to drop close to 0..at first it was quick and I found a leak in the fitting on the back of the passanger side head..
Old Sep 17, 2012 | 11:44 AM
Shattered's Avatar
Shattered
psi setting is at 65, return line is good, just running a stock pump, I have a fuelab I was gonna put in, but don't want to do that much work. Maybe just get a walbro and call it BUENO
Old Sep 17, 2012 | 11:46 AM
Shattered's Avatar
Shattered
it takes about 2 minutes to drop to zero, but I cannot find a leak anywhere, unless it's small enough I don't notice a whole lot of fuel. right now I am doing injector o-rings and have everything apart. probably be a good time to look closer while it's all apart.
Old Sep 17, 2012 | 08:43 PM
beanhead6D5's Avatar
beanhead6D5
Double check every fitting! The smallest leak will cause trouble.
Questions,What type of fittings? Hard lines with flare JIC or rubber lines with push lock JIC fittings?
I had trouble with rubber lines and push locks.I went to hard lines and did JIC flare fittings.No more probs.
Mine bleeds down like Joe's does.Takes about the same time.
Old Sep 17, 2012 | 09:56 PM
Shattered's Avatar
Shattered
Rubber with push locks and 6an fittings
RICHXL7
Dec 26, 2017 09:25 AM
Matt Newby
Jul 22, 2016 05:39 AM
1966Tbird
Sep 15, 2009 05:05 PM
jtttj
Jul 5, 2008 09:03 PM
808trucken
Sep 19, 2007 07:59 PM
