Extreme Bogging (Not Mudding)
Old Sep 16, 2012 | 02:27 PM
devino246's Avatar
devino246
Originally Posted by 77 2wd
ok so its a 2bbl on an adapter plate on a 4bbl intake, and i was just checking things out while it wastnt running and i was throttling it, and i see that where the adapter plate meets the manifold, there is some gas seeping out on both sides, could this cause the bogging?
If there's gas seeping out when the engine's off, there's air going in when the engine's running. That vacuum leak is probably what's causing your problem. Replace those gaskets to get rid of your vacuum leak.
Old Sep 16, 2012 | 03:27 PM
big-ugly's Avatar
big-ugly
You definitely found one issue.
Old Sep 16, 2012 | 03:54 PM
4x4 Bart's Avatar
4x4 Bart
Carb probably to small. When you give it full throttle under load does it bog then backfire and come to life? Is it wanting to run hot?
Old Sep 16, 2012 | 04:04 PM
77 2wd's Avatar
77 2wd
Originally Posted by devino246
It may be working, but just not very well. An engine without a load on it won't require as big of a squirt to get going. Definitely should check the pump to see if it's shooting two solid streams. The diaphragm is probably hardened up and not working well.
To the OP: Pull the air cleaner off your carb (engine off) and look down the throat of the carb while opening the throttle. You should see two solid shots of gas.
By the way, those mixture screws are the idle mixture screws. Adjusting those will make no difference off idle.
yeahh they are very solid streams of gass
Old Sep 16, 2012 | 04:06 PM
77 2wd's Avatar
77 2wd
it doesnt bog down then come back to life, if you give more than 1/8th pedal it just straight bogs down, even if you hold the gas to the floor for 30seconds or more no change, just steady 10mph bogging
Old Sep 16, 2012 | 04:07 PM
77 2wd's Avatar
77 2wd
the gas only seeps out when the engine isnt running, doesnt seep out when its running
Old Sep 16, 2012 | 04:10 PM
77 2wd's Avatar
77 2wd
i suppose that would explain the hiss i hear but cant findd, if it is sucking air would this cause the bogging?
Old Sep 16, 2012 | 04:39 PM
big-ugly's Avatar
big-ugly
Well the lack of fuel/vacuum leak would cause a bog.
Old Sep 16, 2012 | 04:48 PM
77 2wd's Avatar
77 2wd
alright well im gonna go put another gasket on it, and see if that fixes it, ill keep ya guyss postedd
Old Sep 16, 2012 | 07:46 PM
77 2wd's Avatar
77 2wd
well ill be darned, that it was it!! my bogging has improved by 90% she is very much drivable noww!! i still think there is a little bit to be desired even with that little tiny holley. i do have another question though, i advance my timing, little by little to get it right, and i adjusted one more time and it ran fantastically, but i guess it was advanced too far, becausde it wouldnt crank when it got hot, soo my question is why does it run so much better, and yet not supposed to be that far advanced?
Old Sep 16, 2012 | 08:17 PM
hasteranger's Avatar
hasteranger
most engines make more power running with the timing advanced a fair bit... problem is if you advance it too far it is prone to detonate, so you don't want to run on the edge. though the compression on that thing should make detonation a near non issue.
Old Sep 16, 2012 | 08:23 PM
big-ugly's Avatar
big-ugly
Did you experience "dieseling"?
That happened to me for the first time a couple weeks ago with my 429. Sure was interesting when I turned the engine off and it wanted to keep running!
Old Sep 16, 2012 | 08:27 PM
  #28
77 2wd's Avatar
77 2wd
not quite sure what you mean by detonate but i backed the timing off a bit where the power was really good just so it would start better while hot, cause when i advanced too far it would drag while trying to start while hott
Old Sep 16, 2012 | 08:28 PM
  #29
77 2wd's Avatar
77 2wd
not quite sure what you meann, but nothing wierd happened so i dont think i have
Old Sep 16, 2012 | 08:31 PM
  #30
big-ugly's Avatar
big-ugly
Detonating is pinging. That is like smacking your pistons with a sledgehammer. Dieseling is when you turn the ignition off and the engine keeps trying to run, and it fires a few more times even though the engine is "off"
