I've been thinking about getting a newer car eventually, since my 21 yr old Mazda is beginning to get worn out. Sure, I could save a bundle and get something a few years newer but still not from the past decade or so. One thing that's moved higher up on my priority list for a newer vehicle is safety. The "all steel battleship" mentality gives a false sense of security, its a proven fact. Fuel economy, power and comfort all come to mind too. I like my F250 for what it does, but today I noticed people were blowing my doors off on the freeway while I was pushing 75 in the right lane. I'll be the first to admit that it's old, outdated technology. We'll see how the Ecoboost, 5.0 and 6.2 hold up over time.
Which means I dont need to revv into the stratosphere to make the same amount of torque. Why would you need to revv to 6000+ rpm anyways lol
These EcoBoost makes the same torque your 460 does from ~1500RPM all the way to 6000 RPM. While a 460's torque peaks early and starts to rapidly drop off.
That extra rev range gives the engine the ability to drop down more gears when needing to pass, attack big hills, etc..
I have mixed feelings on the entire topic. My grandpa always leases his trucks on a 2 year lease I think, so he gets to go through a lot of the new stuff. His last 3 trucks were half tons, 2 with the 5.4 and the most recent with the 5.0. I don't know the power numbers on the 5.4, but it feels like the 5.0 would eat it alive. Of course my old 5.8 wouldn't touch it from the factory, but if I were to buy a brand new truck with a 5.0, or even a 3/4 ton with a 6.2, I'd be too afraid to touch the motor. It all seems far too complicated for me. That's why I like these old trucks, I can maintain it myself. And if I would stick the amount of money into my current truck that I'd spend on a new truck...well I'd have quite the machine. But even if I stuck all that money into it, I'd doubt I could still match the fuel economy numbers they are achieving.
the newer trucks are not that hard to work on. with even a basic OBD2 code reader you can track down most issues. having the correct tools for the job makes it that much easier.
i love my '91 but theres no way i could daily drive it. the power,interior space,wind noise would get to me very quickly. but i use my '91 for plowing snow in the winter and hauling crap in the summer and shes as reliable as clock work and always does whats asked...even if its not quickly.
all that being said, i had the pleasure of driving a 6.2 f150 over the last few days..wow is all i can say, that would be my pick in a new f-150. the power is crazy and the sound is even better. plus i would be very happy with the 12/16mpg numbers because as of now i'm very used to single digit mpg numbers with my V10...not that it bothers me any.
I dont care what anyone says, I would own a ecoboost in a heartbeat
Me too. When this motor was first introduced in the 2010 SHO, dyno graphs showed torque peak at a straight line, beginning at around 1500 RPM all the way to redline, which meant to me that there's some PCM programming holding things back. A lot of companies have tuned these things safely and reliably to put down at least 400 HP at the wheels, and still get over 20 MPG.
I haven't worked on one, but they're still like most gas engines from the last 50 years--they need fuel, spark and air. Plus there's an alternator, power steering pump, water pump, A/C compressor. They're made from an engine block, crankshaft, pistons, cylinder heads, camshafts and valves--just like virtually every other engine. Oh, and they have a computer that tells you what's wrong some or even most of the time--which is similar to the '87-'96 era of Fords.
Jason
Very well put. Some people are just afraid if change. Just like guys taking off EFI to put a carb on
That 6.2 is a brute! I think its the big block of todays world lol
Put power and economy aside, (which the newer ones own us in) people will tell you that
our old trucks will last longer. I see this as false simply because our trucks are older and
have been tested and tried with mileage and years, and I wouldn't doubt it if these
newer 2011+ models could double our mileage and use. I love everything about the
newer trucks, but there is something you cant pull me away from our old horses. It might
have to do with that old rumble you get from a pushrod V8, and its simplicity, no need
for high tech computers/sensors and dashboards that light up like a tree at Christmas.
There's a LOT to be said for the older simplicity. Knowing that if anything breaks, all you need to fix it are some cheap parts and a few wrenches.
Newer vehicles you need to order the parts from nasa, special tools from ford, and an advanced engineering degree from MIT. Even with all that, you still need the arms of a 4th grader to fit them in to any spot in the engine compartment.
I do agree with what you're saying - the new vehicles could very well prove to last twice as long as the old ones. Technology is a great thing.
But when purchasing, taking pride in self sufficiency is no less a serious consideration than taking pride in owning a flashy new truck.
Just a question of personal priorities.
I like old trucks, and old tractors. The world can go to hell and I'll still be driving them. No question the newer ones are better. But it's very nice not to have to rely on somebody else to fix them when they break down. Just pure simple pride, hard to put a price on that.
A lot of the Old VS New is perception.
In 10 or 15 years, people will probably look at the EcoBoost as old antiquated technology compared to what they will be driving then. Then there will be old curmudgeons saying "give me an ecoboost over these complicated new trucks".
I personally would like to have most any of the new trucks, but I can't afford the payments. On the other hand, I would love to have a truck from the 30's or 40's, (or 50's - 70's...), I love their simple functional beauty, but I can't afford them either!
These new engines (well I don't know about the DI ecoboost), but the 5.0/3.7/6.2 are simpler to work on if anything.
There is no EGR, no air injection and no distributor. The only emissions "junk" on most modern ford engines is the canister purge valve. And most sensors can be easily unbolted and replaced without too much hassle.
For me, I'm just not going to ever finance a vehicle again. Maybe if they hold up well I'll end up with one in 20 years but if I can't pay cash for it I'm not going to buy it.
And I don't see the point of being able to haul and tow that much with a "half-ton" truck. The whole point of a truck in that class is for people who don't need to haul that much so they don't have to spend as much. Don't build me an F150 that can haul the whole world, build me a truck I can actually afford to buy and drive every day.
I had the pleasure of test driving a brand new 5.0 F150 last summer.. a good friend of mine does dealer deliveries/transfers, and no I wasn't kidding it was a pleasure to drive. The motor makes very good power and the 6-speed trans always seems to keep it right where it needs to be, the interior is beautiful, seats comfy, and creature comforts very easy to get used to. The truck I drove is the exact same configuration as mine.. extended cab 4x4, and the things you notice right away are the difference in handling and the extra weight.. feels like my truck with 500lbs of crap in the back. The new 5.0 definitely makes more power than my 5.0 but it wasn't a lot more, I'd say the old beast would give the new one a run for the money but I don't think for a second it would beat it.. maybe if I get 4.10s under her. And I couldn't believe how clean, uncluttered, and bare looking it was under the hood.. makes our engine bays look like something exploded. So yeah I would love to have one of these new truck.. wouldn't bother me a bit to retire the old girl.. though I'd probably keep the motor for some other project.
