brake fluid level sensor
Old Sep 15, 2012 | 10:33 AM
puttster's Avatar
puttster
I installed a master cylinder from a 1988 Ranger/Bronco II on my 1965 Ford. Worked out okay and now I would like to wire the brake fluid level sensor to a warning light in the cabin. I see though that it takes a three spade connector. Assuming I can find the connector, which wires should I use to light the light when fluid is low?
Thanks
Puttster
Old Sep 15, 2012 | 11:35 AM
Puddy's Avatar
Puddy
Post deleted, Sorry wrong diagram, spent the last hour trying to figure out the difference.
Old Sep 15, 2012 | 03:32 PM
puttster's Avatar
puttster
would it be correct to say the TN/LG wire is to test the light? The black is GND and the other one (can't see color) comes from the warning light in the 12v "run" condition? So I would cut the TN/LG?
puttster
Old Sep 15, 2012 | 04:37 PM
Puddy's Avatar
Puddy
The tan /light green is the key on 12v power. Then black is ground, and The other I couldn't make out, and that diagram was for a 2002 ranger, I apologize hard to research on a iPhone. But I do have a tip. Get the painless 2 wire low brake pressure switch. Less headache.
http://m.summitracing.com/parts/PRF-80174
Old Sep 16, 2012 | 01:29 AM
puttster's Avatar
puttster
OK thanks. I'll check the Bronco Forum.
JNG6
Feb 10, 2018 11:58 AM
puttster
1983 - 2012 Ranger & B-Series
Jan 24, 2014 12:14 PM
puttster
1978 - 1996 Big Bronco
Sep 17, 2012 10:57 PM
nighthawk285
May 31, 2006 02:53 PM
94BlackF150
1997 - 2003 F150
Jan 31, 2005 10:17 AM
